FI Exhaust... im lost..
Originally Posted by down_shift
If you're going to internals etc. Don't do an exhaust now.. Do it when you get everything else put in next year... and fabricate something from scratch.
It's pointless to buy an exhaust now.
If you want an exhaust because you still want to mod with the TN kit etc, look into Nismo/Fuji both are 3" dual tip.
my Nismo exhaust produces pretty well....only negative is, it's expensive, and you don't use the Ypipe that comes with the kit, haha.
I would look at the AAM exhaust for sure. As for making 700 with Stage II the turbo in that kit can flow to almost 800 CHP. Thats good for high 600s low 700s easy with cams. 15 PSI and 550 RWHP is with 8.5:1 compression pistons and rods ONLY. No ARP heardware, no headgasket, no cams, no water/meth injection, no sleeves, nothing but pistons and rods. And I think you would be surprised how much boost this motor can take.
Originally Posted by Quamen
700 whp is a bit high. The stage II is a T66 if I am correct and my T70 is rated for 650 whp worth of air flow. Might be wrond though.
erickim080387
Southern California
Dec 18, 2006 05:15 PM
chickmagnet
Southern California
57
Jul 3, 2006 05:49 PM
Jason@Performance
Dec 1, 2005 09:02 PM
Peking
May 31, 2005 07:50 PM
