12psi daily driven?
Old Apr 3, 2006 | 05:57 AM
chris'smax's Avatar
chris'smax
Default 12psi daily driven?
I am going to be running 12psi on my vortech kit along w/:
Nismo cams
Greddy Emanage(blue)
Power Enterprise 510cc injectors
ATP Boost actuated 3" cuttout
Aftermarket Headers
Coolingmist water/alcohol injection
Zeitronix WBO2
ARP rod bolts
Now i am going to be getting my car back this week and i am now worried about running that much boost on a stock block. I have researched alot and it seems that alot of motor failures have been a result of tunning errors. So the question is will this be a relatively reliable setup with a conservative tune and the correct amount of timming pulled.
Also what kind of #'s can be expected from this setup? Around 420whp?
Old Apr 3, 2006 | 04:08 PM
chris'smax's Avatar
chris'smax
come on guys i have searched through many threads. I have seen many threads that talk about blowing motors, but rarely do they state what the cause was. I know a vq30 can take 12psi easy, but it seems most of the guys on here get nervous when going over 11psi
Old Apr 3, 2006 | 04:22 PM
booger's Avatar
booger
Going with the W/M sprayer will help alot . I would think about getting a return fuel system to supply them 510's
Old Jul 27, 2007 | 05:44 PM
TTRANK's Avatar
TTRANK
12psi is a lot for a stock block. The Vortech comes on in the high rpm so you might be ok. Still might want to make sure you have enough money for a build when the time comes.
Old Jul 27, 2007 | 06:12 PM
Mr_pharmD's Avatar
Mr_pharmD
i would not push it over 9psi on stock block unless u have the rev up engine. I would just save up another 3g for a built shortblock and boost the hell out of it.
z2g's Avatar
z2g
^^Daym man, I think he would have answered his own question by now
Old Jul 27, 2007 | 06:20 PM
DMK's Avatar
DMK
There are several people pushing the 2.87 pulley on the stock block. I believe TIMROD is hitting almost 13psi, stock block and vortech fuel system for many many miles. The WM Injection will help a lot, since you can run more boost without the danger.
Out of curiosity, why did you get rod bolts?
Old Jul 27, 2007 | 07:14 PM
GTM's Avatar
GTM
Vendor - Former Vendor
I wouldn't be too worried about it, since its a supercharger kit the power won't come on suddenly and you won't hit peak power until redline. Most engine failures are due to too much boost/power in the torque peak of the engine (mid range) which causes mainly turbo cars to fail. 420rwhp on a stock block with a supercharger? I say no problem.
P.S. This is assuming you have an adequate EMS and tuner
-George
GT Motorsports
Old Jul 27, 2007 | 08:31 PM
Hexxum001's Avatar
Hexxum001
I'm running the 2.87 pulley on the stock block. I hit 10.8psi and thanks to Sam and George @ GTM, my G35 runs flawlessly.
Old Jul 28, 2007 | 04:56 AM
doug's Avatar
doug
any reason you bumped this?
Old Jul 28, 2007 | 01:13 PM
OldManZ350's Avatar
OldManZ350
35,000 with no problems.
Old Jul 28, 2007 | 01:24 PM
taurran's Avatar
taurran
This thread is old...
Old Jul 28, 2007 | 05:21 PM
nomyth46's Avatar
nomyth46
its all about a/f ratio and cylinder pressure!!
Old Aug 2, 2007 | 01:03 PM
chris'smax's Avatar
chris'smax
Dayyyyuuummm how did i miss this!
thanks for the help guys but i don't even own that car anymore.
Man this thread brings back some bad memories
Old Aug 2, 2007 | 01:11 PM
scotts300's Avatar
scotts300
Why? Did it blow up? What boost and octane?
Old Aug 2, 2007 | 01:20 PM
chris'smax's Avatar
chris'smax
no,
It was a 2000 maxima which came originally equiped w/ a vq30. I swapped in a vq35 using the the timming components from the vq30. In order to do this you had to use cam re-position adaptors in order to use the Vq35 cams (nismo cams in my case). After multiple attempts to get the cam timming right and using several set of adapters i gave up and swapped in the vq30 cams. Then when we hooked up the blower it started making noises (not sure if it was a bearing issue or not). After all the headaches i finally sold the car w/ just the vq35 in it and bought a new Z. Been happy ever since
BTW a guy followed up behind me and completed the same exact setup a few months later and made like 430whp. Needless to say i was pissed my setup didn't work out.
Old Aug 4, 2007 | 01:45 AM
silver nismo's Avatar
silver nismo
Good tuning and temp. cooling in all aspects should help a lot.
Old Oct 8, 2007 | 01:03 PM
Equate's Avatar
Equate
Chris'smax send me my tires! its been 5 months!
Old Oct 8, 2007 | 01:14 PM
chris'smax's Avatar
chris'smax
Man i already pm'd you a long time ago explaining that i could not find the tires and asked for a address to send you a check to refund you the 30 dollars for shipping cost. The sale was for the wheels and tires that were mounted. I was basically GIVING you tires becuase i had no need for them and asked that you just paid for the shipping. PM me with a respones.
Old Oct 8, 2007 | 01:25 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
WTF is going on??
