Motor back in but it wont start. Emanage?
Old Apr 17, 2006 | 07:41 PM
G352NV's Avatar
G352NV
Default Motor back in but it wont start. Emanage?
Put my motor back in my Z finally! Car turns over but doesnt start. Heres a little background on the car. I bought the car with a blown motor. The car had a Greddy kit on it with EM blue. I took the kit off and Im putting the car back to stock. When I took the EM off I found that most of the wires just spliced in. All but a orange one. This one was cut, I put it back togeather and cut the spliced wires off. It looks like there are other wires from the stock harness spliced into each other. I cant tell if this is factory or OEM. I tried to download a copy of the EM instructions but my adobe is acting up. Any info from you EM guys would be great! Also is there anyway to check the spark on this car?
Old Apr 17, 2006 | 10:01 PM
overZealous1's Avatar
overZealous1
you can put an inductive timing light on the signal wire to the coil pack. there is alot of wires that get hooked up. would be easy to tell if i could see it all, but your best bet is to keep trying to download the wiring manual. need to get going, but will check back with ya to see if you get it figured out.
good luck man!
Old Apr 18, 2006 | 11:26 AM
theking's Avatar
theking
The one you put back together could have been the CAS wire. Did it have one of Phunk's CAS kits?
Old Apr 18, 2006 | 11:41 AM
hndumafia's Avatar
hndumafia
orange wire on the wire harness for the ecm is for the mass airflow sensor. just to make sure that should be pin number 51 which if you are looking at the harness is on the third row from the top, on the side of the harness, 8 wires left of where the harness is split in the middle (that is if you are looking at the harness so the side with the 5 seperated wires are on the left side). i dont know if that helps at all but i hope it does. also this info is from the 2003 service manual. i'm not sure what year the ecm you have is or if it has changed, so i just thought i'd mention that.
Old Apr 18, 2006 | 12:01 PM
G352NV's Avatar
G352NV
Thanks! Ill check that out. Im headed out right now to DL the EM instructions. At this point Im getting NO spark,none.
Old Apr 18, 2006 | 12:09 PM
hndumafia's Avatar
hndumafia
^^ perhaps you drained the battery from trying to start the car before. (if this is a completely rediculous statement please disregard it. i can install parts, but definitely don't really know what i am saying as far as diagnosing problems)
Old Apr 18, 2006 | 12:10 PM
G352NV's Avatar
G352NV
Yeah full charge.
Old Apr 18, 2006 | 12:11 PM
lucidazn's Avatar
lucidazn
I face the same problems. Running on reflash right now... still trying to get ahold of Sharif..
Old Apr 18, 2006 | 05:38 PM
G352NV's Avatar
G352NV
Lol, I just found the problem. I went to a buddies dealership and talked with a service guy. He really was kind of stumped and then he said. You know that car has a system that will not allow the car to start right. Right then it hit me! I bought the car from a dealership and at the time they couldnt find the key. The guy told me that he would send me a new key because he had to order it from Nissan. The key came about a month later. SO, my guy at the dealer told me today the key has to be programed to match the car. I guess the key has a chip in it. The part that sux is I have to take the car to the dealer to have this done. I now have to finish my install and tow it to the dealer. Looks like Ill be calling the dealer that sold me the car.
Old Apr 18, 2006 | 05:43 PM
rookie's Avatar
rookie
The immobilizer. Not sure if the Z has a security light on the dash, is it lit when the key is in acc or on position?
Old Apr 18, 2006 | 05:46 PM
G352NV's Avatar
G352NV
Yeah he said if that light is on then its a no go and it is.
Old Apr 18, 2006 | 08:31 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by G352NV
Put my motor back in my Z finally! Car turns over but doesnt start. ?
If the car turns over, it isnt the immobilizer...when the nissan immobilizer is engaged, the car will not even turn over...what size injectors are you running? how are they scaled in the ECU..or at all? does flooring the pedal to the floor while turning the key help it start up? possibly too rich at start up--need to suck some air into the sytem (with flooring the pedal-opening the throttle)
hmmmm, good luck
Old Apr 18, 2006 | 09:27 PM
G352NV's Avatar
G352NV
Car is all stock now, it has no spark. The tech at nissan said it would have no spark if the immobilizer was working right. He also said the light would be on if the key wasnt right. The lights on and it doesnt have spark so I think its the immobilizer. In the end it doesnt really matter. The key has to be set for the car. So if this isnt the problem after I get it programed then Ill go from there. But I think it is.
Old Apr 19, 2006 | 02:42 AM
g35pm's Avatar
g35pm
I've tried starting my car with my credit card key. The engine tries to turn over (you can hear it), but it won't turn over.
Old Apr 24, 2006 | 09:41 PM
G352NV's Avatar
G352NV
Well all is good. I took her to the dealer and they charged me 104.00 to program it. Car started first turn, I drove it home. Thanks guys.
Old Apr 24, 2006 | 09:45 PM
Julian@MRC's Avatar
Julian@MRC
hmmmm, good luck
Actually your wrong, the immobilizer will allow the car to crank but it will not start.Trust me, I went through the same thin a while back..
Old Apr 24, 2006 | 09:47 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Did you put the Z tube on yet?
Old Apr 24, 2006 | 09:48 PM
G352NV's Avatar
G352NV
Sure did thanks!
Old Apr 24, 2006 | 09:59 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Sure did thanks!
Sweet!
Fixxxercask
Nov 9, 2015 11:10 AM
