tn st with or with out ????
Old Apr 26, 2006 | 09:37 PM
LOUPESO's Avatar
LOUPESO
Default tn st with or with out ????
i am about to install the turbonetics st on a 04 g35 and wanted to know what you can suggest . UR pullies, jwt flywheel, kinetix or motordyne etc .. thanks in advance .
Old Apr 26, 2006 | 10:01 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Ehh.......... I would have suggested doing some research before you go to install a turbo kit???
Old Apr 26, 2006 | 10:19 PM
Z BOY's Avatar
Z BOY
yes.
Old Apr 27, 2006 | 04:59 AM
LOUPESO's Avatar
LOUPESO
im not doing the install my tech is (but I can if I had the time and a lift) just want some advice on what works with what .. Im new to the v35 scene so any help would be great .. Hey I can answer any BMW question if there is any !
Old Apr 27, 2006 | 05:31 AM
G3.5T's Avatar
G3.5T
Not sure what your asking but I have the TN kit on my G35 and have the MD iso thermal spacer kit. It works well, no problems.
Old Apr 27, 2006 | 06:44 AM
MIAPLAYA's Avatar
MIAPLAYA
All of those should be fine yes...
Old Apr 27, 2006 | 06:47 AM
wtf no turbo's Avatar
wtf no turbo
Not being a TN guy ill tell you what i do know.Be careful with any type of aftermarket part that ups airflow.E.G. exhaust plenum spacers etc.Now this does not purtain to all install but because TN lacks a adjustable tuning device.All that being said I believe TN is looking into unichip and any shop can sell you a utec of Vcon.Pullies i think would be ok but i would stay away from any underdrive systems since the tend to rob the waterpump.
Get it installed stock with some gauges.Check A/Fs and go from there.Need more power first grand you spend should be in the piggyback dept.
LOUPESO's Avatar
LOUPESO
so UR pullies are ok to install with FI ( TN ST) ? or would the jwt flywheel be better .. Thank you
Old Apr 27, 2006 | 06:48 AM
MIAPLAYA's Avatar
MIAPLAYA
If you aren't installing a clutch at the same time then theres no point in doing just the JWT flywheel...
Old Apr 27, 2006 | 06:52 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I would advise you that these additional mods may make you run lean. The more you mod from just the kit on the ECU flash the more chance you have of needing more tuning-thats getting into piggybacks at a minimum maybe fuel system+injectors if you want at that point in time. With that being said because your running the stock exhaust I think the flash will be sufficient-but theres always that chance. Good luck.
