Head strengthening mod
Old May 8, 2006 | 09:30 AM
  #61
G352NV's Avatar
G352NV
inside of the head in the cooling passage, at the floor of the head there is a structural beam cast in that is designed to strengthen this area between the cylinders. this casting brace is nice and flat and is centered directly under this casting hole. it is nearly impossible to take a good pic of it, so trust me, it is there, lol.
You tighten the bolts down onto the structural beam. This is my guess
Old May 8, 2006 | 09:33 AM
  #62
overZealous1's Avatar
overZealous1
Originally Posted by MRC Motorsports
No, from what he said it sits upon the cylinder walls as a support for the heads.Unless I am missing something..Im confused
the bottom of the bolt rests on a support beam INSIDE the head, to further support this area and help it not lift from the block. this bolt does not go all the way to touch the block, that would well destroy everything, lol. it is super hard to get a picture down through that hole to show it to you.
Old May 8, 2006 | 09:36 AM
  #63
overZealous1
Originally Posted by meatbag
beat me to it. Is the nut reverse thread so the bolt wont back out?
not reverse thread. there is no directional rotation in the head, lol. therefore reverse threads would make no difference. the upper nut is just a lock nut to keep it from backing out. plus you will need to seal it in as it is going into a cooling passage. this is basically a permanent mod that would never need to be removed, so you could use some pretty nasty stuff to lock it in.
Old May 8, 2006 | 09:37 AM
  #64
overZealous1
bingo!!!
Old May 8, 2006 | 09:40 AM
  #65
theking's Avatar
theking
It's not touching the hg. It is just supporting the bottom of the head. It's not touching the cylinder walls either. It's just acting as a brace between the cylinder for the head. It's keeping the thin area between the cylinders down. Here's a pic of the bottom of the head. There's only 2 of them per head.
How exactly does this work?
Here is a picture of the head where the stud is, and the second one is a picture of the block.So your mod runs a full length stud through the hole for the allen bolt, and into the head gasket that lays upon the surface where the two cylinder walls meet. wouldnt this in theory not only damage the head gasket in that area, but also PUSH the heads AWAY from the motor, when you want to hold them down??
Old May 8, 2006 | 09:46 AM
  #66
overZealous1
you can also see in the pic from mrc, how this area is the thinnest area for combustion to make it into the cooling system. that is a slit inbetween the cylinders that is a steam crossover.
File Type: bmp
Old May 8, 2006 | 09:51 AM
  #67
Julian@MRC's Avatar
Julian@MRC
ok, I see now...
Old May 8, 2006 | 10:45 AM
  #68
bigbri's Avatar
bigbri
Yo man pm me with you # I want to talk to you about this...
Old May 8, 2006 | 11:28 AM
  #69
westpak's Avatar
westpak
SFZCC
Ok I have a question, I am trying to understand where the loads come from and where they are applied on the head that would cause that section to lift.
Could this be because people building motors are normally going to 0.020 oversize on the cylinder diameter but the head is not being machined to match therefore leaving a small ledge providing a surface to have load on it?
Old May 8, 2006 | 05:28 PM
  #70
overZealous1
it would not matter at all if there was a ledge left on it, the whole combustion dome is what is holding the combustion in, thus the lifting force acts against that. this area between the cylinders is the weakest link. i am trying to come up with a good analogy, hmmmm......
ok, take a high pressure water line, like 10" diameter. put a cap over the end, and just use 4 bolts to hold the cap in a nice semetrical square pattern. now pressurize that water line till you get a leak. where do you think it will leak first? at the areas least supported, directly inbetween the bolts holding the cap down. now what would happen if you put a whole bunch of weight on 2 sides of the cap, they will no longer leak. not sure if that is more confusing, but the idea is the same, lol.
on my car and others, the center cylinder has been the prob. not to say this is across the boards, but there seems to be a pattern. the center cylinder, on both sides of it, is closest to the water passages. more "weight" needs to be put on the sides of this cylinder to help keep the leaking at bay. that is what this mod does. not neccesarily more weight, but a more solid surface less prone to movement.
Old May 8, 2006 | 06:34 PM
  #71
atlsupdawg#2's Avatar
atlsupdawg#2
Talk about being slow....I just finally got a grasp of this problem..
So in a nutshell, there is a leak in the head to cylinder mating surface due to the higher pressure from F/I. In turn, the leak is contained within open deck portion of the block which also happens to be the coolant passage. This is what is causing the excessive high pressure in the coolant system forcing all the engine coolant into the overflow bottle..
Is this correct??
Would it be possible to further remedy the problem by o-ringing the head? Essentially, you could just machine a small groove around the perimeter of the combustion chambers on the head equal to the diameter of the cylinder bores, minus a few thousandths. Then just drop in stainless o-rings, your head gasket & torque away. Combined with this mod it should totally eliminate the problem..
Old May 8, 2006 | 07:36 PM
  #72
overZealous1
Is this correct??
yup, you are finally up to speed, lol. i personally plan to o-ring my motor. it can only help.
Old May 8, 2006 | 09:32 PM
  #73
AmyCroft's Avatar
AmyCroft
Smile Excellent
Now that you have the Stud and Anti-Spinout Lock Nut issue explained. O-Ring ala Supra will take the sealing issue to a Engine Tear-Down level.
Your Load Head fix is nice because the Head is not removed. And only requires
the Valve cover to be removed.
O-Ringing is a Engine out.
Cheers Amy -
Old May 8, 2006 | 09:52 PM
  #74
overZealous1
Cheers Amy -
yes, this is truely a stroke of luck this can be accomplished with out pulling the heads and only the valve covers. this is as easy as it will ever get for this type of mod.
Old May 8, 2006 | 10:03 PM
  #75
Nismo350ZRT's Avatar
Nismo350ZRT
Oz, will this work on the revup heads?
Old May 8, 2006 | 10:16 PM
  #76
AmyCroft's Avatar
AmyCroft
Smile Bye the way - I will bet the Japanese Crowd Will be at your door..
OverZealous:
I know the Japan Side of 350Z people will be on your door soon. Get a Patent or Patent Pending.. A few bucks now and If Nissan adds it to the common block - you will score big time.
Sounds Small - Upside Big.
Cheers Amy -
Old May 8, 2006 | 10:26 PM
  #77
overZealous1
i personally have not torn into the rev up motor yet. i could not imagine nissan changing the casting process though.
Old May 8, 2006 | 11:00 PM
  #78
overZealous1
OverZealous:
Cheers Amy -
you have a good point. i have a feeling there is a handful of people already on this site searching for this bolt size, lol.
btw, just to help you guys out, if you pull your motor apart to figure out the thread size and pitch, you won't find it local (99% of you atleast) and your car will be down for days, even if you do find it, for shipping. just a warning, so you don't end up with downtime if your car is already running.
will call a patent attorney first thing in the morn.
Old May 8, 2006 | 11:15 PM
  #79
aalzuhair's Avatar
aalzuhair
Good for you man yeah do it ... I hate to see someone else claim this mod.
Keep all your notes, copy of this thread, anything that shows when you started working on this mod..
Old May 9, 2006 | 09:40 AM
  #80
SinCity350Z's Avatar
SinCity350Z
Track Whore
Thats f**king awesome Scott! You gotta PM me a link to these threads when you start them lol. I just found this one and its already 4 pages long. You are one sick f**k trying to fit that 6-71 on your Z, but I like it . If anyone could figure it out, its you. I will have to get one of these kits from you for sure! Got anything else coming up that I will want to buy?
