TUrbonetics Turbo UPgrAde??
I have the 60-1 and I want a little more power in my high boost setting. I know their coming out with their tuner kit, but it does me no good b/c I have everything already except for the turbo. My questions are as follows:
-How much is the t66 that comes with the 1.5 stage or w/e?
-Do they upgrade your old turbo?
-What am I supposed to do with the old one?
-Do I need a bigger intercooler for the bigger turbo??
1. you will send in your T60-1 turbo and they make it into a T66 for about $450 . So that answered most parts of your questions. According to MIA/Turbonetics, the Spearco IC is can/good enough with the T66. I don't know how much the w/e( water/ehtnaol injection kit ) will cost. But with all these upgrades, you will need to built your block.
yea my block is built, so im looking at some serious downtime I would assume huh? I have injectors and everything so my car is ready for a bigger turbo. Since I now know they modify my turbo, the question how long does it take them? and how much is it exactly with shipping to do all this?
A T66 compressor max flow is 72 lb/min or roughly 720 HP of air. With a built motor and cams thats about 700 WHP depending on tuning etc. You can order a custom T66/Stage V turbo now if you want. Just call REggie and tell him you need a T66/Stage V ceramic ball bearing with a .77 A/R turbine...
Well Im pretty sure my turbo seal is leaking oil or something, so Im probs going to have to send the turbo back anyways. I might as well just upgrade to the T66 and officially get some serious power out of this car. MIA how long am I looking at without my car if I want to get this done?????
Originally Posted by 35ounces
Rob,
what do they do to upgrade it to a T66? Do they just use the housing and replace the compressor side or what?
the T66 is efficient in higher boost areas not down low correct?
Originally Posted by TurboTim
We have a GT35R bolt-on turbo with T4 hotside and TO4E compressor for this kit:^)
What are the characteristics of that? What kind of power numbers with what boost levels can be expected? Where is it efficient?
Originally Posted by Alberto
Whats max boost on a T66 on our engines? And about how much whp can it realistically make?
Eventually I'd like to to see 500-550whp with a built motor. However, my concern with the T66 and Stage 2 is that we will have to run high boost (14psi+). From what I have seen, a lot of the TT guys with built motors running 12psi or higher are having head lift issues and other problems. I'd even be interested in 475-525whp with lower boost levels.
