Ran my car....
Originally Posted by chimmike
you're joking, right? with 700whp? drag radials be enough?
I personally am not a big fan of full slicks. A nice tall sidewall M/T drag radial hooks just as well and you don't fell like you're going to lose the rear end the entire way down the 1/4 mile.
He needs to pull out that negative camber and actaully start letting that 295 use it's entire width. I'm basically at stock ride height and I was only putting down about 3 inches of tread on each tire under hard acceleration before I pulled that negative camber out. He's probably putting down even less of the tire.
Originally Posted by bigbri
I would think that 295 drag raidels would be enuff...
You need a full racing suspension bro might as well get knew axles while you at it.
Originally Posted by BriGuyMax
Drag radial equipped vehicles have dipped well into the 7 second 1/4 mile range which is WELL OVER 700whp. It's not all about tire..it's about how you set it up too.
Ok so 600 or 650 for extra killing power is all i need. I might even stick with 550 after hearing about this. What is up with our cars. They just don't hook. Lets see after the suspension and camber mods.
Well .... finally two people wanna agree with me here. His tires are MORE than enough for 700hp. His tires are good for 10s, 9s, maybe even 8s if driven right.
My best alignment spec for launching was
F (not that it matters much) - -0.7 camber, 0.0toe
R -1.0 camber, 0.05toe (toe at 0.0 felt squirrely past 80mph ... but a lil toe in helped it out a TON)
SPC rear adjustments at $210 will equalize/adjust nearly any Z/G dropped up to 2.5" back into factory spec. But like BriMax alluded to ... a lowered car isn't what you want for racing anyways. Given your setup and your current struggles, your best bet/remedy is a fresh (nearly camber free) alignment.
They say their stuff is good for + - 2 degrees its not. And you always want a little toe in, because as you learned under acceleration you get some + toe. So if you set to 0 toe it feels like crap...
Originally Posted by Alberto
I have that set-up + Kinetix arms and I cant get better than -1.9 camber in rear, and Ive raised my car 2X
Kinetix Front A... or rear camber arms? I've seen a G here dropped (I think ~2.4") get right back to -1.4. This is with the SPC rear arms (350Evo fronts, irrelavent here though). As always ... all cars are a bit different.
That said, I think the SPC is the most adjustable out there.
We missed you.
I thought Rob had set the camber up for you once specifically for drag racing. did that help? Dale had slicks so he had to race in comp rod. I don't know if he was able to hook up or not.
Originally Posted by sentry65
bigbri, do you have an aftermarket LSD?
my car fishtailed a lot before I got mine
Nope stock lsd...Thanks for all oyur help guys...I'm def going to fix the camber and go back out there and see what happens....I'm def not running it like this again...I was scared and so was everone at the track...they were making me run alone and holding off the other lane because I was getting so crazy..
Originally Posted by GTNPU Z
Hmm? With that much power, you definitely need to step up to coilovers. You'll be able to tune it more to reduce wheel hop so you can keep those tires on the ground. Once you get those & fix your camber, I think you'll be good to go. Just be careful you don't break an axle. Speaking of which, are you planning to upgrade that in the future? You might want to look at these badboys in the future...
http://www.forgedinternals.com/store...cat=261&page=1
BigBri: Absolutely AMAZING man... I am sure you will get that beast under control. I have the Tein CS & use the softest setting for the rear and a mild setting up front. I hope that will give me a bit better traction, but I think I will have to go with rear camber arms and traction rods. Let me know what you try, I would be very interested to hear what helps you correct this problem.
--B
I am an idiot in this department but would the rear end have anything to do with it? I know its been proven wrong but alot of people say the Z's don't have a good rear end for drag racing? Ignore my ignorant post if it is indeed a bunch of BS.
Here is a quote from a fourm where there are 9 and 10sec cobras that I talk to and am trying to set up a race with...a couple of them were there...one guy said and this is a straight quote from the other fourm.....
Originally Posted by BlackVenom96
hahaha, yeah man, you could hear your tires screaming the whole way down the track. even in 4th gear you werent getting traction. that car is FUKin nuts man.
Originally Posted by fowlman01
Time for full out slicks. DR's aren't any good for that kind of HP. I had traction problems last night with my relatively stock Z on 275 Goodrich DR's. Got better after I roasted the hell out of them at 18# of air pressure, but they were still slipping.
Just read some more of the posts. You can't hook up with the camber you have. Your whole car has to be set up for whatever racing you are going to do with that much HP.
All you need is some suspension work and your car will hook up. Good Luck.
http://www.mickeythompsontires.com/press_10_18_04.html
yeah I think an aftermarket LSD will help tons
instead of fishtailing and going sideways, with a stronger LSD it I not only gets better traction, but it keeps you facing straight much better than before.
you'll get less wheel hop with solid motor mounts and solid diff mounts - SPC is coming out with solid diff mounts in a month or two.
your engine must be making so much torque, the stock engine mounts are probably turning to mush while the engine tries to twist itself out of your engine bay, which hurts traction because the driveshaft is physically moving side to side instead of simply turning and doing nothing else
solid rear diff bushings will keep the rear diff from squishing and rotating side to side. It'll stay solid and simply turn the axels. It's kinda the same thing as solid motor mounts, only instead of having an effect on the driveshaft, it keeps the axels from physically moving up and down and instead just rotate
that bushing movement creates bouncing energy which will lift/bouce the tires off the ground or at least reduce the steady gravity force pushing down on the tires
getting rear suspension arms with spherical bearings might help slightly too, though only a little
