Ran my car....
Old May 26, 2006 | 05:52 PM
  #141
bacalhau16's Avatar
bacalhau16
I used BFG's DR's on all my turbo honda/acura projects and loved them.
Old May 26, 2006 | 06:41 PM
  #142
tonio's Avatar
tonio
Hey Bri, if it helps any I had an APS TT putting down not even close to what you do (417whp) with the eibach setup and bad camber. Even with slicks I could not gain traction for sh*t at the track, I know the issue has been beat into the ground but slicks are useless without a good suspension setup.
How is the traction on a regular road above 60mph?
Old May 26, 2006 | 07:43 PM
  #143
bigbri's Avatar
bigbri
It hooks on normal road around 70mph....I am getting a camber setup and fixing this problem...
Old May 26, 2006 | 09:19 PM
  #144
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by bigbri
What kind of susp. setup do you have man...??
Nismo S-tune, SPC camber arms, toe bolts. Camber set to -.5 degrees per side. I might pull it all the way out to zero when I get more power. A local Z tuner is working on a full swappable (in under an hour) drag suspension for the 350Z, I'll be prototyping it on my car.
Old May 26, 2006 | 10:04 PM
  #145
mraturbo's Avatar
mraturbo
That sounds fun...Please let me know how it works. Would love to have a simple solution to swap from Roadrace to Drag...
M
Old May 27, 2006 | 04:00 AM
  #146
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
M
Will definitely post up with all the info when it's done.
Old May 27, 2006 | 09:27 AM
  #147
overZealous1's Avatar
overZealous1
one more little trick is to unhook one end of your front sway bar. it allows the front to pull up easier shifting weight to the rear.
Old May 27, 2006 | 10:25 AM
  #148
mraturbo's Avatar
mraturbo
Thanks...
Goodluck
Old May 30, 2006 | 04:51 PM
  #149
fowlman01's Avatar
fowlman01
You asked me earlier to post this if I found it. Here it is:
http://www.bgnra.org/Chris_Chow_Dyno_Burn.htm
Old May 30, 2006 | 05:03 PM
  #150
Quamen's Avatar
Quamen
I want that car!
Old May 30, 2006 | 06:39 PM
  #151
FEARSM's Avatar
FEARSM
Not a bad run. You dont need slicks. You may want to consider going to a smaller rim, like a 15 or 16 inch rim. The added sidewall makes a HUGE difference. I used the BFG's before. 315/35/17. I was able to cut a 1.700 on my 6pd (700rwhp launching at 6.5k) and 1.68 on my auto (launching at 10 psi). I switched to the MT on a 16 inch rims and my 60 fts average around 1.55 to 1.52 with the auto. I would suggest you give them a try. Even the 17s grip really well. I just think its kind of funny that most of the people telling you to go to slicks probably never ran an 11 sec pass at the track themselves. Get your suspension sorted out and you will be fine. The DR will hold if you heat them up enough. You need to drop your tire pressure though. I run mine at about 14-15 psi. My car is nice and stable up top even at 130+ traps.
Old May 30, 2006 | 07:28 PM
  #152
royce so's Avatar
royce so
a smaller rim won't clear the brakes.
Old May 30, 2006 | 07:49 PM
  #153
JimRHIT's Avatar
JimRHIT
Wrong .... there are many 16" wheels that will clear the Track Brembos and a few 17s that'll clear even a 14.25" setup.
Weld Pro-StarXP will clear most brake setups on the Z.
Old May 31, 2006 | 10:11 AM
  #154
Osix350Z's Avatar
Osix350Z
You need to correct your camber issue and get a set of slicks.. With your trap around 128 and the fact you let off, with traction you should be trapping in the 130's. Once you hook up you're good for 10's.
Old May 31, 2006 | 10:21 AM
  #155
G352NV's Avatar
G352NV
Bri is everything cool? Havent seen you post for a while.
Old May 31, 2006 | 10:49 AM
  #156
Philthy's Avatar
Philthy
Boost Junkie
His probably out enjoying his ride and hunting down motorcylces...
Old May 31, 2006 | 01:14 PM
  #157
FEARSM's Avatar
FEARSM
If he runs slicks with a radial tire up front the car will be even more unstable. He has to run a skinny with a bias ply up front or the rear end will be all over the place.
Old May 31, 2006 | 01:45 PM
  #158
failsafe306's Avatar
failsafe306
Bri, I don't know if anyone's mentioned it yet, but you may want to fix your camber and get some slicks.
Old May 31, 2006 | 01:50 PM
  #159
bigbri's Avatar
bigbri
No dought...
Old May 31, 2006 | 01:51 PM
  #160
bigbri's Avatar
bigbri
Yea man just been busy with work..... I havn't even been driving the beast...
