idle problem
Old May 31, 2006 | 07:17 AM
z350phille's Avatar
z350phille
none yet, working my *** of
need to get some money for a 3" exhaust also..
Old Jun 4, 2006 | 04:32 PM
Dirty Dave's Avatar
Dirty Dave
Just say this thread for the first time. I too keep throwing a p0011 code cam timing advance bank 1. Has anyone figured this out yet ? This is stopping me from getting my car inspected. If it helps I am running a greddy tt with u tec and fully built long block with jwt cams.
Old Jun 5, 2006 | 08:00 AM
mistaboosta's Avatar
mistaboosta
did this problem start after your engine rebuild?
Old Jun 5, 2006 | 08:32 AM
Dirty Dave's Avatar
Dirty Dave
Yep this happend after the motor rebuild. So it has to be because of the new cams or the shop that installed it messed up the sensors not real sure but i hope someone figures this out cause i cant pass ny state inspection because of it.
Old Jun 5, 2006 | 09:06 AM
z350phille's Avatar
z350phille
Im going to uninstall my greddy TT kit and probobly get the motor out again..
Old Jun 5, 2006 | 11:05 AM
mistaboosta
trying new cam sensors might reveal some answers for us.
Old Jun 5, 2006 | 11:37 AM
z350phille's Avatar
z350phille
wonder how much it costs..
seems like an endless moneypit that car
do you know the part number it will be my last try before i pull the engine again?
Old Jun 5, 2006 | 02:33 PM
mistaboosta
nope i dont know the part number
i was used to call my wrx a moneypit but this car is becoming the money Grand Canyon
Old Jun 5, 2006 | 06:40 PM
Dirty Dave's Avatar
Dirty Dave
Lol this car is just as bad as a wrx except being a V6 you need to buy two of everything that breaks.
Old Jun 5, 2006 | 10:40 PM
z350phille's Avatar
z350phille
Hehe.. I also had a Scooby before this car
those were the days, sub 4sec 0-60!
Old Jun 5, 2006 | 11:09 PM
mistaboosta
yes those were the days
Old Jun 9, 2006 | 01:15 PM
Dirty Dave's Avatar
Dirty Dave
Any work on the p0011 fix yet ?
Old Jun 9, 2006 | 02:43 PM
z350phille's Avatar
z350phille
Not me anyways...
Just threw a 0300 so im looking at ignition stuff atm...
Old Jun 10, 2006 | 01:41 AM
mistaboosta
the p0300 multi cylinder misfire is a by-product of p0001.
still workin on it but nothing yet. The worst thing is, you can't raise the idle no way!
Old Jun 10, 2006 | 02:30 PM
Dirty Dave's Avatar
Dirty Dave
So your saying the p0011 is happening because of the p0300 or vice versa, because i was told a p0300 pops on mostly due to a lightened fly wheel ?
Old Jun 11, 2006 | 02:27 AM
mistaboosta
i dont have a light flywheel, i suppose the p0300 is happening because of the p0011.
Up to now we know that:
-This happens to cars with built engines.
-Kills the car @ idle.
-Car throws a p0011 and p0300 code
-Car jerks while driving @ %5-10 throttle.
Old Jun 12, 2006 | 01:05 PM
mistaboosta
double post
Old Jun 12, 2006 | 09:15 PM
  #38
z350phille's Avatar
z350phille
I found this in another thread.
OverZaelous1:
"well to further get into this, i have now called nissan trying to get part numbers for the left and right bank intake cam gears. guess what, nissan only has one part # and the parts guy says they can be used on either side!! confusing huh? it is SUPER important to mark ALL your cam gear placements, valve bucket placement, and cam saddle palcement upon disassembly. i had to build a VQ35 last week where the guy who tore the motor apart did not mark anything!! it was a reputable shop also that definately should have known better!! i had to look super close at the wear marks on the back side of the cam gears and match the seating marks to the correct sides.
so yes the intake cam gears look and are indexed identically, and nissan can't even help ya with part numbers to get them back on right.
yancy, one of the easiest ways to tell if this happened is to read your 02 sensor readings. bank 1 (pass. side) should be running very lean, with bank 2 running very rich. also, my part throttle was junk and would always toss the po300 code. when i got past 3000rpm, the thing went like a raped ape though and felt great.
hope ya get it figured out."
qoute end!
Seems like i good idea to test that anyway.
/Phill
Old Jun 12, 2006 | 10:45 PM
  #39
overZealous1's Avatar
overZealous1
one thing to check also, is pulling your cam and crank sensors and make sure they are clean. it is a slim chance, but when cams and bearings break in they can create a metal slurry in the oil. the magnetic sensors picks this slurry up and if enough attracts on the sensor, it will give a false signal. always a good idea to check them about 500 miles after any engine build.
Old Jun 12, 2006 | 10:47 PM
  #40
z350phille's Avatar
z350phille
Thx will do!
