350-400 wrhp with a SC?
Old May 31, 2006 | 06:24 PM
sentry65's Avatar
sentry65
the burninator
i dunno, what whp are you at right now? what are your other mods?
Old May 31, 2006 | 07:00 PM
Mr_pharmD's Avatar
Mr_pharmD
I don't have sc yet but am debating on getting the 3.12 pulley. This will be on an auto g35 coupe with h/e/ hi flow cat. I'm about to purchase some 380cc injectors and I'm afraid it might be too small. I heard the 380cc is good for around 385 hp at 90% duty cycle so will I be around that range with the 3.12 pulley and tuned with the unichip and walbro pump?
Old May 31, 2006 | 07:01 PM
sentry65's Avatar
sentry65
the burninator
IMO i'd go for 440 injectors - trust me when I say it's better to have more injector than you need than not enough. I was hoping 440 would be enough for me, and ended up needing to go to 550's
Old Jun 1, 2006 | 03:11 PM
kevinbonds's Avatar
kevinbonds
Originally Posted by trefling
Procharger & Vortec will easily get you over 400rwhp, but sadly the stillen will get you at most 385 at the wheels.
I would say the stillen kit is the worst FI kit in regards to cost versus power gain plus you can't have a real intercooler with the stillen kit as you could with vortec/procharger
Did I really here someone say this. So an air to water intercooler is not a real intercooler. Last time I checked an air to water intercooler was a very effective way to intercool a FI motor. You should tell some high end sports car manufacturers that, maybe they made a mistake. The air to water intercooler is very effective on the roots based supercharger because the circulating water moves the heat away from the plenum so that it doesnt heat soak. Its a fact that water dissaptes heat better the air in certian applications. (I said certain applications like the stillen set up and others similiar to it) As long as the heat exchanger is mounted where it can recieve sufficient air-flow like the stillen is mounted it makes for an extremely efficient system.
To answer the original question. You can make 350 HP easy on any one of those kits. The stillen stage 4 properly installed will get you close but not exactley 350. Its about what kind of powerband you want. The vortech and ati, make power but there peak HP is high in the RPM range. The stillen since it;s a roots makes power instantly most closley resembeling an NA car. smooth linear powerband. I have ridden in an ati, and a stillen. I personally like the powerband of the stillen better for me since off the line acceleration is what i like. Thats just my opinion. The vortech and ATI are great kits. But you cannot compare any of the SC kits to a turbo. totally different animal with much more upward potential. My .02
a-town204
Mar 23, 2016 12:41 AM
KWT_350z
Tuning
Sep 29, 2006 02:41 AM
KWT_350z
Aug 24, 2006 03:41 PM
johanna1
Mid-Atlantic
Jun 30, 2005 11:52 AM
johanna1
Jun 28, 2005 09:05 AM
