need help quick
Old Jun 3, 2006 | 06:59 PM
fito's Avatar
fito
Default need help quick
Has anybody used 750cc Rc injectors with a E-manage ultimate?
Old Jun 3, 2006 | 09:44 PM
D350Z10's Avatar
D350Z10
I believe that Emanage cant flow or control injectors that big it doesnt have complete control over the injectors like the UTEC of a Standalone.
Old Jun 3, 2006 | 10:15 PM
fito's Avatar
fito
I have tuned alot of cars with the 650's. Iam right now in Orlando FL. trying to tune it but Iam having a lot of problems with this one, and Iam wondering if the injector are to big. The car run perfect (598hp @19psi) but wont idle!
Old Jun 3, 2006 | 10:51 PM
booger's Avatar
booger
Sharif has mentioned in several threads that you need to flash the ECU for 550's and then finish scaling them with the EM . I think TS can flash for 750's though
Old Jun 4, 2006 | 03:31 PM
Gman2004's Avatar
Gman2004
I ran RC 750's with the EU. You have to flash the ECU to 650's so you can scale the 750's.
Old Jun 4, 2006 | 04:18 PM
theking's Avatar
theking
On another note, where are you in Orlando. I'd love to meet you and see some of the tuning. You at Titan or Aerocomp?
Old Jun 4, 2006 | 04:55 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Its hit-or-miss with 750cc injectors and the EU. Usually the idle is pretty rough, and we have to run really low fuel pressure to get the cars to idle cleanly.
How much fuel pressure are you running?
Old Jun 4, 2006 | 05:59 PM
fito's Avatar
fito
Iam running 35psi with the vacum on Sharif.
Old Jun 4, 2006 | 06:00 PM
fito's Avatar
fito
Iam @ Central Florida Turbo.
Old Jun 4, 2006 | 06:27 PM
Sharif@Forged
Forged Performance
Cancel the injector scaling in the parameters section...turn it off.
Instead, goto the airflow adjustment map, and put -50% the entire map.
At this point, try free revving your engine to about 2200rpm or so. What is your AF ratio under this scenario? If it is near 14:1, then your solution is an idle increase, via TS or AAM.
Old Jun 4, 2006 | 06:30 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
have you tried dumping a lot of extra fuel in during idle. it has helped my idle a few times...
im in orlando too. CFT has some fast hondas!!!!
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
