UTEC OPEN LOOP Problem
Old Jun 12, 2006 | 01:04 PM
mistaboosta's Avatar
mistaboosta
Default UTEC OPEN LOOP Problem
Hi,
My utec is starting to use Open Loop fueling before the map value reaches 0 psi (I've set MAP threshold to 0 psi). I couldn't find out why it does so. Here is a log I've taken today.
Old Jun 12, 2006 | 01:09 PM
mistaboosta
3165 -3.4 3.03 19 00 00 3.27 +36.4 8.5 Ecu. +0.0 2.50
3177 -3.4 3.00 20 00 00 3.29 +36.4 8.5 Ecu. +0.0 2.50
3165 -3.4 3.03 20 00 00 3.34 +36.4 8.6 Ecu. +0.0 2.54
3189 -3.3 3.09 20 00 00 3.33 +36.3 8.7 Ecu. +0.0 2.52
3211 -3.3 3.07 19 00 00 3.39 +36.3 8.8 Ecu. +0.0 2.56
3198 -3.3 3.07 20 00 00 3.36 +36.2 8.8 Ecu. +0.0 2.52
3198 -3.2 3.09 20 00 00 3.42 +36.3 9.0 Ecu. +0.0 2.54
3198 -3.0 3.17 22 00 00 3.56 +36.3 9.4 +33.4 +0.0 2.68
3214 -2.4 3.25 22 10 00 3.78 +35.3 10.0 +21.7 +0.0 2.76
3236 -1.9 3.29 23 20 00 3.98 +34.3 10.6 +21.5 +0.0 2.80
3255 -1.9 3.27 24 20 00 4.04 +34.3 10.8 +21.4 +0.0 2.76
3226 -1.8 3.25 24 20 00 4.08 +34.3 11.0 +21.3 +0.0 2.80
3236 -1.5 3.29 23 20 00 4.15 +34.3 11.3 +21.1 +0.0 2.82
3242 -1.3 3.39 23 20 00 4.19 +33.3 11.6 +21.0 +0.0 2.80
3274 -1.2 3.35 24 20 00 4.38 +33.2 11.8 +20.9 +0.0 2.86
3303 -1.1 3.35 25 20 00 4.38 +33.3 11.9 +20.9 +0.0 2.86
3271 -1.0 3.35 24 20 00 4.40 +33.3 12.0 +20.9 +0.0 2.80
3310 -1.0 3.39 24 20 00 4.40 +33.3 12.0 +20.9 +0.0 2.82
3284 -1.3 3.41 24 20 00 4.34 +33.3 11.9 +21.0 +0.0 2.82
3303 -1.3 3.31 23 20 00 4.29 +33.4 11.7 +21.0 +0.0 2.80
3300 -1.5 3.29 23 20 00 4.20 +33.4 11.6 +21.2 +0.0 2.74
3306 -1.7 3.35 22 20 00 4.14 +33.3 11.4 +21.3 +0.0 2.76
3310 -1.9 3.37 23 20 00 4.12 +33.3 11.4 +21.4 +0.0 2.76
3360 -1.8 3.35 23 20 00 4.12 +34.3 11.5 +21.4 +0.0 2.76
3330 -1.8 3.31 22 20 00 4.13 +34.3 11.4 +21.4 +0.0 2.80
3336 -1.9 3.37 21 20 00 4.14 +34.2 11.6 +21.4 +0.0 2.80
3370 -1.8 3.35 22 20 00 4.14 +34.3 11.5 +21.4 +0.0 2.80
3367 -1.8 3.33 23 20 00 4.15 +34.2 11.5 +21.4 +0.0 2.78
3350 -1.9 3.37 22 20 00 4.13 +34.2 11.5 +21.4 +0.0 2.82
3367 -1.7 3.35 22 20 00 4.19 +33.3 11.8 +21.4 +0.0 2.74
3373 -1.8 3.39 22 20 00 4.13 +34.3 11.5 +21.4 +0.0 2.74
3397 -1.9 3.33 23 20 00 4.14 +33.3 11.7 +21.4 +0.0 2.74
3422 -1.9 3.31 23 20 00 4.14 +33.2 11.7 +21.4 +0.0 2.74
3422 -1.9 3.31 22 20 00 4.16 +33.3 11.7 +21.5 +0.0 2.72
3415 -1.9 3.31 21 20 00 4.13 +34.3 11.6 +21.5 +0.0 2.74
3439 -1.9 3.35 23 20 00 4.16 +34.3 11.8 +21.5 +0.0 2.80
3439 -1.9 3.27 23 20 00 4.17 +35.3 11.9 +21.4 +0.0 2.84
3432 -1.9 3.25 20 20 00 4.14 +35.3 11.8 +21.4 +0.0 2.80
3422 -2.1 3.31 20 20 00 4.12 +35.3 11.7 +21.7 +0.0 2.68
3429 -2.5 3.25 20 10 00 3.96 +36.4 11.3 +21.9 +0.0 2.64
3432 -3.1 3.09 20 10 00 3.84 +37.2 10.9 +22.0 +0.0 2.58
3436 -3.4 3.07 19 10 00 3.85 +37.3 11.0 +22.0 +0.0 2.58
3472 -3.5 3.07 19 10 00 3.85 +37.2 11.0 +22.0 +0.0 2.56
3468 -3.3 3.25 20 10 00 3.85 +37.3 11.1 +22.0 +0.0 2.60
3447 -3.4 3.11 20 10 00 3.86 +37.3 11.1 +22.0 +0.0 2.60
3457 -3.4 3.15 20 10 00 3.86 +37.3 11.0 +22.0 +0.0 2.64
3494 -3.4 3.11 19 10 00 3.86 +37.3 11.1 +22.0 +0.0 2.60
3479 -3.5 3.07 20 10 00 3.87 +37.2 11.2 +22.0 +0.0 2.60
3468 -3.5 3.05 20 10 00 3.87 +37.2 11.1 +22.0 +0.0 2.58
3479 -3.6 3.03 20 10 00 3.87 +37.3 11.1 +22.0 +0.0 2.56
3472 -3.6 3.11 19 10 00 3.88 +37.2 11.2 +22.0 +0.0 2.56
3475 -3.7 3.13 20 10 00 3.87 +37.2 11.1 +22.0 +0.0 2.58
3501 -3.8 3.01 20 10 00 3.88 +37.2 11.3 +22.0 +0.0 2.56
3479 -3.7 3.17 20 10 00 3.88 +37.4 11.2 +22.0 +0.0 2.58
3501 -3.8 3.09 19 10 00 3.89 +37.3 11.3 +22.0 +0.0 2.56
3494 -3.7 3.11 20 10 00 3.89 +37.3 11.3 +22.0 +0.0 2.60
3508 -3.7 3.13 20 10 00 3.89 +37.3 11.3 +22.0 +0.0 2.56
3523 -3.7 3.13 20 10 00 3.89 +37.3 11.4 +22.0 +0.0 2.56
3494 -3.7 3.07 19 10 00 3.90 +37.3 11.3 +22.0 +0.0 2.58
3508 -3.8 3.05 20 10 00 3.90 +37.3 11.4 +22.0 +0.0 2.64
3505 -3.7 3.11 20 10 00 3.90 +37.4 11.3 +22.0 +0.0 2.54
3508 -3.7 3.07 20 10 00 3.90 +37.3 11.4 +22.0 +0.0 2.58
3534 -3.6 3.21 19 10 00 3.91 +37.3 11.4 +22.0 +0.0 2.66
3516 -3.6 3.09 19 10 00 3.91 +36.3 11.4 +22.0 +0.0 2.66
3546 -3.5 3.13 20 10 00 3.92 +37.4 11.5 +22.0 +0.0 2.58
3523 -3.5 3.11 20 10 00 3.92 +36.2 11.5 +22.0 +0.0 2.68
3542 -3.6 3.11 20 10 00 3.92 +37.3 11.6 +22.0 +0.0 2.58
3549 -3.5 3.13 19 10 00 3.92 +37.3 11.5 +22.0 +0.0 2.58
3531 -3.7 3.07 20 10 00 3.93 +37.3 11.5 +22.0 +0.0 2.58
3568 -3.7 3.11 20 10 00 3.93 +37.3 11.6 +22.0 +0.0 2.58
3546 -3.8 3.05 18 10 00 3.93 +37.2 11.6 +22.0 +0.0 2.50
3546 -4.7 2.66 10 00 00 2.39 +38.2 6.8 Ecu. +0.0 2.05
3549 -6.5 2.29 2 00 00 1.69 +33.3 4.9 Ecu. +0.0 1.76
3411 -7.8 1.96 1 00 00 1.37 +34.2 3.8 Ecu. +0.0 1.68
3584 -8.1 1.96 1 00 00 1.48 +33.2 4.3 Ecu. +0.0 1.62
3472 -8.3 2.00 0 00 00 1.48 +33.3 4.2 Ecu. +0.0 1.68
Old Jun 12, 2006 | 01:11 PM
mistaboosta
as you will se the car is using the %10 and %20 colon just under 0 psi. The TPS is between %18 and %20 while this happens. The TPS Treshold for mapping is set to %30. RPM Treshold for OL Fueling is 2500 rpm.
Why does my car use %20 and %10 colons before 0 psi ?
Old Jun 13, 2006 | 12:50 AM
mistaboosta
no one knows? ?
Old Jun 13, 2006 | 09:52 AM
USED's Avatar
USED
Why did you choose 0 psi for your MAP threshold? I've always used a low number like 3.
Old Jun 13, 2006 | 11:18 AM
mistaboosta
coz sometimes i like to drive half throttle and I didn't want to run 14.7 AFR and 35+ ignition timing while pushing 1-2 psi to my engine which the stock ecu would do.
Old Jun 13, 2006 | 02:30 PM
turboz33's Avatar
turboz33
Did you try 1 psi as your threshold? If so, what affect did it have?
Old Jun 13, 2006 | 03:20 PM
mistaboosta
yes i did, nothing changed.
Old Jun 13, 2006 | 05:08 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Are you sure you have Speed Density Mode set, load indicator set to MAP, and Open Loop MAP Threshold set correctly?
"When Fuel Mode parameter is set to the Speed Density option, Open Loop TPS Threshold is disabled and Open Loop MAP Threshold is enabled. " That lets you enter open loop fueling based on a MAP value rather than TPS. The Open Loop RPM Threshold speciifies when open loop fueling is enabled.
I'm guessing that one of those values is not set right. You can not specify TPS threshold and RPM threshold and a MAP threshold value which is what you indicated you have set.
COLUMN <> COLON!
Old Jun 13, 2006 | 11:26 PM
mistaboosta
i'll take a screenshot today. Yes the speed density mode is on, and is mapping via MAP.
The TPS threshold is not working as you mention. But still the car uses %10 column under 0 psi and uses ecu coulmn @1-2 psi during 6th gear.
Old Jun 14, 2006 | 03:30 AM
USED's Avatar
USED
You should really call TXS directly and speak with Jermaine or Nathan. We have been working close with Turbo XS regarding load variants on FI VQ cars and UTEC.
Again, I have never used 0 as a MAP threshold number. I'll try this on my next UTEC/FI VQ tune (this week) and see what happens. Maybe the UTEC is having difficulty discerning vacuum/pressure with 0 as your threshold. Did you try 2 as your MAP threshold? Did you put your MAP sensor calibration numbers into your parameters? Maybe the tolerances are off just enough to be attributing to your problem.
I believe 3 as MAP threshold is still safe. I have never run into an issue where 1-2 psi w/higher ign timing was dangerous. Did your logs give you an indication of knock at that level in different situations?
Old Jun 14, 2006 | 03:50 AM
mistaboosta
Thanks for the help I'll try making it 3 now. The calibration sheet that came with my MAP sensor had numbers with 4 digits and it was impossible to use them as inputs for my UTEC. I'm suspecting that I received a d-tec map sensor, do you think that this is possible? Here is a picture of the map sensor that I got.
Old Jun 14, 2006 | 04:17 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
I've never seen the d-tec sensor but that is what my map sensor looks like.
Old Jun 14, 2006 | 06:16 AM
USED's Avatar
USED
That is the correct MAP sensor. Let us know how it works out.
Old Jun 14, 2006 | 06:22 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
if you couldn't use the map sensor calibration numbers that came on the tag did you at least recalibrate to get new numbers using the method in the manual?
Old Jun 14, 2006 | 02:39 PM
mistaboosta
I tried the calibration method for map but it didn't work for me. The utec was showing 12 psi where as gauge was showing 15 psi. So after a lot of trials i found some numbers that seem to work very close to my gauge.
Old Jun 15, 2006 | 09:46 AM
BlackTuner's Avatar
BlackTuner
Can you please post a screen shot of your special constants and open loop fueling parameter?
thanks,
Jermaine~
Old Jun 17, 2006 | 11:11 PM
KPierson's Avatar
KPierson
I'm having a very similar issue. My MAP threshold was set at 2psi and I would enter the 10% column at 0psi. I upped the MAP threshold to 3psi and the 10% column still triggered at 0psi.
Any idea what causes this?
Old Jun 18, 2006 | 08:53 AM
mistaboosta
have u calibrated the map ?
is it showing exact same values as your gauge?
I'm busy nowadays but i'll take the screenshot shortly.
Old Jun 18, 2006 | 09:38 AM
KPierson's Avatar
KPierson
No, I have not calibrated my MAP. The values provided with my MAP were not values that could be inputted in to the UTEC. The dashboard is very close to my guage.
I don't see how that can be the problem though, as the UTEC reports 0PSI. If the unit wasn't calibrated properly it should still hold off until IT sees 2 or 3PSI (depending on setting). I'll try to take some screen shots later today of my settings.
