Turbo Survey.....
Old Oct 16, 2006 | 06:59 PM
k3silk's Avatar
k3silk
1) What turbo's are installed? JWT TT
2) How long have they been installed? 4months, 4k miles
3) What whp or psi are running regularly 6.8PSI , smokey turbos, etc.)? No problems knock on wood.
Old Dec 3, 2006 | 04:44 PM
TTRANK's Avatar
TTRANK
Bump to keep this going. I have been researching TT/ST kits all day and this does help!
Please post up or even make this a sticky!!!
Old Dec 3, 2006 | 09:34 PM
XuperXero's Avatar
XuperXero
This thread is actually very helpful! I'd love to see more owners setups and how long they ran for with what amount of power or kits.
Old Dec 4, 2006 | 10:58 AM
sugarspunZ's Avatar
sugarspunZ
1) What turbo's are installed? APS ST
2) How long have they been installed? 3 months
3) What whp or psi are running regularly? 9psi 375whp
4) What issues have you encountered(blown engine, smokey turbos, etc.)? this kit was purchased used. had really bad boost drop due to a bad coupler. simple fix then ran great. now, blown motor do to a terrible mis-shift.
Old Dec 4, 2006 | 01:06 PM
Juztin's Avatar
Juztin
[QUOTE=whip24lash]To the tt or st guys with stock internals...
Greddy 18G's
Like 4 months, current odo says 92k miles, boosted it right around 86k miles
450hp/425tq @ 8.5-9psi, kinda fluctuates from the mbc
Initially had some blue smoke issues that was caused by the lines for the Greddy catch can kinking under high vacuum at high rpm. Swapped to race hoses and no issues since.
I started off just @ the stock pressure level of 7.5 and did 399/380. Then upped the boost w/ a mbc, but since it was only used for like a +1 psi bump or so it fluctuates from 8.5 - 9 psi. I'm going to resolve this here in the beginning of next year when I pick up some 550cc injectors. Probably go with deatschworks, I just got a CJM stage I return fuel sys. I also need to get away from the stock exhaust. I'm going to be shooting for 500 with the 11.5psi springs and exhaust which will be right around 400ish uncorrected HP here in Denver (5800+ feet above sea level). Right now at 450hp corrected, my uncorrect is right around 360. Hopefully the JWT clutch will hold as well aside from the stock bottom end.
Old Dec 4, 2006 | 02:15 PM
k3silk's Avatar
k3silk
1) What turbo's are installed? JWT tt
2) How long have they been installed? 5 months daily driver with 7k on turbos
3) What whp or psi are running regularly? 6.8 spi
4) What issues have you encountered(blown engine, smokey turbos, etc.)? none cross my fingers, Im sure some time i will have to replace my clutch cause im on stock clutch.
Old Dec 4, 2006 | 02:25 PM
redman333's Avatar
redman333
1) What turbo's are installed? TN ST
2) How long have they been installed? 2 months 7k mi
3) What whp or psi are running regularly? 8.5psi 365whp tuned utec
4) What issues have you encountered(blown engine, smokey turbos, etc.)? Turbo seal, burned a/c line, just blew the motor.
Old Dec 19, 2006 | 07:36 AM
AlwaysNBoost's Avatar
AlwaysNBoost
jwt tt
6.5psi
3k on turbos
stock motor/no internals
runs perfect
Old Dec 19, 2006 | 10:25 AM
JETPILOT's Avatar
JETPILOT
1) What turbo's are installed? Turbonetics
2) How long have they been installed? 1 year
3) What whp or psi are running regularly? 9.5psi 410whp
4) What issues have you encountered(blown engine, smokey turbos, etc.)? 2 Turbo's with blown oil seals, A/C mounting bracket failure, overboosting, blown motor
Old Dec 19, 2006 | 12:31 PM
KempieZ's Avatar
KempieZ
This is a good thread! Now I can see if there are more guys out there running aps tt kit on a stock block with 450whp without blowing it. Mine is being installed next week! (of course, it's in the tuning and how you drive it)
Old Dec 19, 2006 | 02:48 PM
TENGAI's Avatar
TENGAI
1) What turbo's are installed? GReddyTT
3) What whp or psi are running regularly? 10psi 469whp
4) What issues have you encountered(blown engine, smokey turbos, etc.)? Blown motor
More turbo goodness in the works for next year
Old Dec 19, 2006 | 03:10 PM
BrianLG35C's Avatar
BrianLG35C
1) What turbo's are installed? APS TT
2) How long have they been installed? 8 months
3) What whp or psi are running regularly? 9psi 442whp
4) What issues have you encountered(blown engine, smokey turbos, etc.)? Blown Motor
Old Dec 19, 2006 | 04:02 PM
lemansz20's Avatar
lemansz20
1) What turbo's are installed? Turbonetics single turbo kit
3) What whp or psi are running regularly? 13 psi
4) What issues have you encountered(blown engine, smokey turbos, etc.)? blown motor, bad idling, smoke, overheating, overboosting, blown a/c line
Old Dec 19, 2006 | 04:14 PM
Cannysage's Avatar
Cannysage
this already exists.
https://my350z.com/forum/forced-induction/227114-your-fi-update.html
Old Dec 20, 2006 | 04:23 AM
ipcheck's Avatar
ipcheck
1) What turbo's are installed? Turbonetics Single Turbo Kit
2) How long have they been installed? 1 year on old engine, 2 months on new
3) What whp or psi are running regularly? 8-9 psi, 370-400 whp
4) What issues have you encountered(blown engine, smokey turbos, etc.)? Blown AC Lines (5 of them), blew one engine due to overboost when vacum line came off, this all my fault of not installing tie straps on the lines...
Old Dec 20, 2006 | 04:43 AM
gringott's Avatar
gringott
1) What turbo's are installed? PE/IHI 1420s
2) How long have they been installed? 1 year 7 months stock internals (about 25K miles on turbos, installed at 39K miles on engine(
3) What whp or psi are running regularly? 6 & 9 psi, 370-400 whp
4) What issues have you encountered(blown engine, smokey turbos, etc.)? One bad oil return line from passenger turbo, poor quality control, after 1 year and 7 months have not yet got replacement part, I had a machine shop resurface the face of the fitting and used JB Weld to repair poor weld job (pinhole leaks). Also one silicon connector at IC developed a 1/8" tear, replaced with thicker connector. Also suffering from rapid rear tire wear out.
Old Feb 1, 2007 | 01:01 PM
Havok_RLS2's Avatar
Havok_RLS2
I have to tell ya.... I'm pretty amazed just how many blown motors there are here in this thread.
bcoffee20
Nov 19, 2015 06:39 PM
