opinions on bored out 3.8 liter darton sleeved blocks?
Old Jul 23, 2006 | 01:21 PM
westpak's Avatar
westpak
SFZCC
I have the same thoughts, I have mine is sleeved and I stuck with 3.5L no need to go with 3.8L just tweak the boost up a little and you will more than make up for it and not have any concerns. I also took the safe way thinking that if anything goes wrong I can still bore the sleeves and rebuild. I can't wait to get it finished.
Old Jul 23, 2006 | 08:33 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by Alberto
Hes not a pansy hes being honest
there is plenty of gasket present... "not an issue"
100mm is the maximum to oversize with the darton sleeves before this theory could potentially become problematic... I think at 100mm, yoy are sitting pretty... larger displacement, more power..without compromising the integrity of the bottom end...IMHO
Old Jul 24, 2006 | 06:32 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The headgasket seating surface is reduced by about about 30%. In all likelyhood, its "not and issue" (inside joke between Todd and I).
Old Jul 25, 2006 | 10:44 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Originally Posted by IceY2K1Max
Anyone try the 4.15L Brian Crower stroker kit($4785)?
You know, I do most of my own work on my G, but this is something I would probably get installed. I wonder approx what the install would run on this...
Dave
Old Jul 25, 2006 | 11:05 PM
Triji's Avatar
Triji
I am thinking about 21 hours to do the Brian Crower set up... I am looking into that as well but when all said and done you are most likely looking at around 10K or so....
Gonna need new bearings, bolts, might as well do the heads while you are in there as well and throw Darton sleves in there...
I might have to wait on this and go for the VB upgrade, 2.87 pulley, 34 tooth CoG pulley, AAM return fuel, Walbro FP, and 440 injectors before I do the BC upgrade...
Old Jul 26, 2006 | 10:58 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Hmm, ok, thanks for the info
Dave
wanderingstuden
Jan 28, 2016 07:03 PM
samansharif
Sep 25, 2015 12:31 PM
