Project SWAP !!!
Old Jun 30, 2006 | 05:50 PM
  #101
symalik's Avatar
symalik
fixed the coolant leak and oil smoke problems? thats awesome! almost done and everything done by yourself at home what a great feeling it must be
Old Jun 30, 2006 | 07:20 PM
  #102
ZU L8R's Avatar
ZU L8R
Viper Sellout
Does this mean I don't get to come over tommorrow?
Old Jun 30, 2006 | 11:25 PM
  #103
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Wow.. amazing.. If I ever go to florida, can I take a look at your car? Maybe even get a ride? Also, I'm going to be asking for your signature..
Old Jul 1, 2006 | 12:10 AM
  #104
Audible Mayhem's Avatar
Audible Mayhem
My350z
yes matt, i will be putting the G back together, the sooner we get that, the sooner we can start on your car!!
yeah the coolant leak was an easy fix, just one of the stock clamps on just a little sideways, and the oil burnt right off the manifold in a couple minutes.
now the battery light stays on really dim and the voltage gauge in the car reads really really high.
i really dont know why it would be reading so high or whats the deal with that. i will be switching batteries in the morning to see if for some reason something went wrong with that
besides that, it was a fun project and will gladly do it again!!
Old Jul 1, 2006 | 05:10 AM
  #105
superchargedg's Avatar
superchargedg
Damn Noobs
jeremy,i doubt switching battery,s is gonna help at all.it sounds like the internal regulator in the alt is bad.
Old Jul 1, 2006 | 05:55 AM
  #106
Audible Mayhem
My350z
thanks man, well the good thing is that i have two of everything!!
kinda... i will figure it out though
Old Jul 1, 2006 | 06:15 AM
  #107
Eazzy's Avatar
Eazzy
Yep ---Alt Prob ---Have it tested
Old Jul 1, 2006 | 11:12 AM
  #108
Alberto's Avatar
Alberto
Cranky FI Owner
Congrats man, I will have a beer in your honor tonight...
Old Jul 1, 2006 | 02:25 PM
  #109
Audible Mayhem
My350z
thanks man, have a few. i got the alternator problem figured out, i think when i had the G wiring harness on the motor, there was a couple different plugs and that was one of them, it did something to the alternator, i switched it with the other one and the car runs great. open wastegates (5psi) is no fun but EVERYTHING is running perfect!!! what a relief!!!!
want to thank matt ZUL8R for all his help coming over and breaking things for me...
i am going to figure out how to get the greddy boost solenoid to stay open using the utec so i can run 9 or 10 psi later since the map i am using to begin is tuned for 11 psi
Old Jul 1, 2006 | 02:30 PM
  #110
ZU L8R's Avatar
ZU L8R
Viper Sellout
I didn't break anything....yet.
Old Jul 1, 2006 | 03:45 PM
  #111
danroydlc's Avatar
danroydlc
thanks guys, i got the electrical problem figured out, it was just a 10 amp little fuse causing the tach and coolant gauge not to work.
now i just need to figure out why the battery light is showing that it is charging almost 18 volts...
check the back of the alternator post you might have shorted the positive terminal to the alternator housing, especially if you have a capacitor mounted in there.
Old Jul 1, 2006 | 03:50 PM
  #112
Audible Mayhem
My350z
yeah see it worked fine and even tested fine, but if the air isnt on it was putting out 17 volts, turn on the air and then it was fine, its no problem now, i switched alternators and it works perfect!!!
Old Jul 1, 2006 | 05:48 PM
  #113
MoodDude's Avatar
MoodDude
Jeremy,
Haven't noticed this thread. Looks like you did a great job! Now you will have a nice problem of finding grip I don't have as much hp as you will have on this beast, and I can't find enough grip from my 295 R-compound tires - great problem to have
Hope you can have her running nicely and join me at Road Atlanta in August!
Mike
Old Jul 1, 2006 | 07:46 PM
  #114
Zexy's Avatar
Zexy
Congrats Jeremy, looks like it's running strong.
Call me upcoming week if you need help with Matt's beast.
Old Jul 2, 2006 | 10:02 AM
  #115
one350zfan's Avatar
one350zfan
Helluva Job. PM me when you take it to the track. I've got to be there for the christening!
Old Jul 2, 2006 | 10:47 AM
  #116
Audible Mayhem
My350z
thanks guys, yeah the weight of the turbo, intercooler, and bigger radiator is very very noticable. damn!!!
can handles a lot different!! ran around for a few hours last night on 5 psi and it was running nice!! i am working on figuring out the utec boost solenoid control and i will be able to kick it up a notch later today!!
i will hope to make some road course events mike, this thing gets really really hot fast though, need to work on some cooling tricks very soon, maybe the air needs to come out to better the cooling and lighten up the front end
Old Jul 2, 2006 | 11:04 AM
  #117
bacalhau16's Avatar
bacalhau16
Wow, what an awesome project to have. Kinda funny seeing two such nice cars in a backyard all torn up like that.
Glad everything worked out for you. Cant wait to see what kinda times you'll get with your new setup. Any ideas on what kinda power you'll be making with 11lbs of boost once everything is ready?
Old Jul 2, 2006 | 11:07 AM
  #118
Audible Mayhem
My350z
have no idea... i know they guy in the G put down high 400s on 10.5 psi i believe. nothing out of the ordinary. i will figure it out pretty soon.
still kinda overwhelming
Old Jul 2, 2006 | 12:09 PM
  #119
MoodDude's Avatar
MoodDude
Did you put an oil cooler on her?
The owner of the shop I go to has a TT 350Z with the Koyo radiator and still has temperature problems at the track. Only cooling differences between my car and his are my oil cooler and the vents in my hood. Yet, I credit most of my cooling to the oil cooler. Although that will add on some weight.
Welcome to the heavy world of TT
Old Jul 2, 2006 | 12:30 PM
  #120
Audible Mayhem
My350z
yeah thanks man, i will be putting an oil cooler on it for sure, that is on the list along with a couple other secret items
