Vortech Question....(3.12 pulley / Tune)
Old Jun 22, 2006 | 09:38 PM
Triji's Avatar
Triji
Question Vortech Question....(3.12 pulley / Tune)
I am getting my Vortech installed as we speak and I have a question about the 3.12 pulley and the SS Box...
I know the kit is tuned out of the box for the 3.33 pulley... What if you put the 3.12 pulley on and bypass the 3.33 pulley altogether... Will the SS be able to handle that without a tune for a bit?? I would like to drive it for a month at least before I go for a tune so I can troubleshoot any problems without 2nd guessing were the problem came from....
Thanks!!
Old Jun 23, 2006 | 05:27 AM
booger's Avatar
booger
You can drive it , but I wouldnt rely on the tune and I wouldnt boost it at all
Old Jun 23, 2006 | 05:50 AM
Triji's Avatar
Triji
Ok, so it would be safer to install the 3.33 pulley for the first month to trouble shoot, then go with the 3.12 w/ a tune at the same time...
Can the stock SS box handle mods like Kenitex Resonated Test Pipes, HKS Exhaust and Crawford Plenum out of the box?
Or should I just say Fug it and get the tune ASAP!
Thanks!
Old Jun 23, 2006 | 06:09 AM
jpc350z's Avatar
jpc350z
Put everything on at the same time and be done with it...If you are gonna have trouble (not likely) better find out with all your mod's...
Old Jun 23, 2006 | 06:10 AM
dimebagdolf's Avatar
dimebagdolf
The SS box can be tuned for alot of mods, but it's supposed to be archaeic and kind of painful.
I'm running the SS box with the mods in my signature. Unless I decide to go for more boost later, I'm good with the SS box.
Old Jun 23, 2006 | 06:12 AM
booger's Avatar
booger
Seems it would be cheaper to have them install the smaler pulley and drive it . I would keep a real good eye on the A/F , but for sure dont boost it alot and not to redline . Drive it for a week and then get it tuned
Old Jun 23, 2006 | 06:18 AM
Triji's Avatar
Triji
OK, Cool thanks for the input... I actually installed the pulley amongst other things on the kit. I have been hangin at the shop to learn as much about the kit as I can (cool guys they let me work w/ them).
I am just gonna leave the 3.12 in there and sched a tune by Thurs next week. I drive about 100 miles a day anyway so I should have a good idea on how she runs.
Thanks. (can't wait to get her back today!)
Old Jun 23, 2006 | 07:54 AM
sentry65's Avatar
sentry65
the burninator
what shop are you having the install done at?
Old Jun 23, 2006 | 08:29 AM
Triji's Avatar
Triji
Hi Sentry!
I am getting it done at Caliente in the Air park Auto Tech.
I like the guys there alot... This is however, their 1st Vortech instal... I have been at the shop alot looking things over as it progressed, even lending a hand on the bracket and some of the piping.
I am going to Dyno Comp for the tune... Do you need to make an appointment there for a tune?
thanks
Old Jun 23, 2006 | 09:36 AM
sentry65's Avatar
sentry65
the burninator
that's cool, hope things go well
yeah you'll need to call dynocomp for an appointment, but they usually can get you in within a day or two
Old Jun 23, 2006 | 09:38 AM
westpak's Avatar
westpak
SFZCC
Don't be surprisd if they can't tune the smaller pulley with the stock setup, the MAF might run out of voltage to tune, you will probably need bigger fuel pump and maybe larger injectors.
Old Jun 23, 2006 | 09:57 AM
jpc350z's Avatar
jpc350z
ThE MAF signal is modified by the S.S box and sent to the ECU...Haven't heard of any one with trouble with smaller pulleys YET!!
Old Jun 23, 2006 | 11:04 AM
westpak's Avatar
westpak
SFZCC
Yes the SS modifies the MAF signal but with more boost you have to be able to bring it down more, and you might run out and max it out and not have enough fuel, it is easier to tune if you have a bigger pump and/or injectors so you have more fuel to start off and start with a lower modified MAF signal so when you near redline and max boost you still have room to modify the MAF signal.
The SS tunes in a unique way, it is not as simple as reducing the MAF signal and you are set you have to start at a set point and reduce the signal but if you start already high you run out of room.
Old Jun 23, 2006 | 11:12 AM
jpc350z's Avatar
jpc350z
I was only referring to the smaller pulley and not maxing the MAF.. Totally agree with upping the fuel delivery..for a safe A/F ratio..The tuning of the fuel map is made simpler when you have ample fuel delivery...
Old Jun 23, 2006 | 11:17 AM
Triji's Avatar
Triji
Great now you guys are starting to F'n confuse me!! STOP IT!!
Now I got to go read up more on this stuff
<----- BIG FI NUB
Old Jun 23, 2006 | 11:32 AM
jpc350z's Avatar
jpc350z
Sorry for any confusion . With the 3.12 pulley and the stock fuel system you will be fine.. Many posters are and still run this way.. All thats being offered is with an enhanced fuel system you get a safer and easier to tune F.I. car...
Old Jun 23, 2006 | 11:38 AM
westpak's Avatar
westpak
SFZCC
Oh OK, you meant to max it out due to the boost like some other kits do, while I meant tuning the SS, which will keep you from maxing out the MAF and going into limp but if not enough fuel to start with you run out of adjustments to keep the Air Fuel from going lean.
Old Jun 23, 2006 | 11:40 AM
jpc350z's Avatar
jpc350z
Cyberspace has it's limitations on communications...
Old Jun 23, 2006 | 12:01 PM
buffmanjeff's Avatar
buffmanjeff
if u want to put the 3.12 on, i'd do it before u place the bracket and blower in the car. Its a pain in the *** if u want to put it on later, cuz i just did it. and you should be fine with the 3.12 on the full vortech kit and ss box. My tuner didn't have any problems. Alot of people have run it and have been fine. However i would get it tuned asap and not boost it, especially if you are running other mods, just to be on the safe side. Good luck.
Old Jun 23, 2006 | 02:49 PM
Triji's Avatar
Triji
Hey, thanks alot guys!
Ya, I got the 3.12 pulley in there and keeping it there. I am going in for a tune next week after I put 500 miles on her... I will not boost her and keep her under 4K rpms until I can get her tuned.
Would 440 RC injectors w/ the stock Vortech fuel pump be ok to run?
thanks for all the help
