boost activation on coolingmist?
Old Jun 30, 2006 | 08:12 PM
nateg35's Avatar
nateg35
Default boost activation on coolingmist?
Can someone who running coolingmist kit show me how to adjust the boost level?. I'm looking to spray @ 5psi. How do I adjust the boost activation?
Thanks
Nate
Old Jun 30, 2006 | 08:45 PM
chris'smax's Avatar
chris'smax
you use a allen key to adjust the screw on the vaccum switch. I believe it comes already set at 5psi. I wouldn't activate it until around 9 psi though.
Old Jun 30, 2006 | 11:05 PM
nateg35's Avatar
nateg35
Thanks Chris...I played around with it and now I dont know what psi it set ...Can I turn it back to 1psi then go up? if yes then how would I know when I get back @ 5psi?
Old Jul 1, 2006 | 05:05 AM
superchargedg's Avatar
superchargedg
Damn Noobs
nate keep me updated on this please.im thinking going this way also.
Old Jul 1, 2006 | 07:46 AM
MoodDude's Avatar
MoodDude
I installed a LED to signal when the pump went on, then drove her around and played with the boost switch to get it set where I wanted.
Old Jul 1, 2006 | 08:04 AM
nateg35's Avatar
nateg35
Good idea...didn't think of it....gonna install the LED...thanks moodDude
Old Jul 1, 2006 | 08:09 AM
booger's Avatar
booger
Not trying to be an a s s . But doesnt it come with instructions on how to set it up ? I was looking at my Snow kit and it shows exactly how to get started .
Old Jul 1, 2006 | 11:09 AM
sentry65's Avatar
sentry65
the burninator
the cooling mist instructions are practically none-existent. They kinda sucks
Old Jul 3, 2006 | 12:43 AM
nateg35's Avatar
nateg35
Not much on the coolingmist kit though...the problem is that I played around and then don't know where is 5psi...Now with the LED came on when the pump is on...I made a couple run and finally tuned it ~5 psi
Old Jul 3, 2006 | 12:52 AM
nateg35's Avatar
nateg35
As I spoke to Sam @ Stillen...he said it's safe with Stillen kit but it would work better if tuned....and Stillen kit LOVES good gas (so I figured water/alcohol should be good...but it just my thinking ) He'll check with Steve to see if they will offer this. I finally put on mine yesterday and felt a little different when WOT (the outside temp around 95F...little bit stronger or maybe it just in my head )
Old Jul 3, 2006 | 03:56 AM
MoodDude's Avatar
MoodDude
Coolingmist instruction exist on their website. The boost switch comes preset at 10 psi. Even with the instruction, nothing works as good as real testing, that is why I wanted to drive it and see when it kicked on. Just like your A/F, I like to know what is going on when I drive it and not just trust the dyno.
Old Jul 3, 2006 | 06:08 AM
superchargedg
Damn Noobs
thanks nate,this is going to be next.
Old Jul 27, 2007 | 05:42 PM
TTRANK's Avatar
TTRANK
I also used an LED on mine. You never know if the boost switch is set right so using the light is the best way.
Old Aug 30, 2007 | 12:33 PM
cmtech1's Avatar
cmtech1
We understand that everyone has a different interpretation of what instructions should be. I will always be the first to say that there is room for improvement. We work very hard to document our product. I am sure that no other vendor has as much data made public about the product as us. all of our instructions are page by page with pictures. If you could help me out and tell me what is so bad about these instructions I would appreciate it. I believe we can always improve and would love your input
Just curious, what do you base that on? Every kit we sell gets these in printed form. These are on CD and printed for vari-cool orders. here are our instructions:
Standard Kit instructions:
http://www.coolingmist.net/instructi...structions.pdf
varicool underhood:
S-HSV
Varicool trunkmount:
standard trunkmount:
boost switch and varicool details, S-HSV schematics:
http://www.coolingmist.net/instructions.aspx
Vari-Cool Technical docs (full diagrams and specifications)
http://www.coolingmist.net/techdocs/vari-cool.pdf
S-HSV technical docs
Boost switch:
http://www.coolingmist.net/techdocs/boostswitch.pdf
hardware and fittings:
http://www.coolingmist.net/techdocs/complete.pdf
software instructions:
trunkmount tank:
http://www.coolingmist.net/techdocs/tank.pdf
S-HSV
http://www.coolingmist.net/techdocs/s-hsv.pdf
Old Aug 30, 2007 | 12:49 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by cmtech1
I am sure that no other vendor has as much data made public about their product as us.
Wanna wager on that?
Old Aug 30, 2007 | 01:24 PM
cmtech1's Avatar
cmtech1
No. Im not looking for an argument. I understand aquamist does a great job of putting specs out for the product I would never dis-agree with that (regardless of how I feel about them). I see very little from the US companies which is all that really matters to our business. I should have specified "US based", but did not think I needed to. Frankly the US companies other than my company have little in terms of technology (In my opinion) so I guess they dont have much to document.
CM
Old Aug 30, 2007 | 01:30 PM
MIAPLAYA's Avatar
MIAPLAYA
CM
I sincerely hope you are not insinuating US companies don't provide adequate documentation. I'll make the general assumption you are referring to Water Injection products and not all manner of performance parts. You are making some pretty far reaching claims about US companies not having much in terms of technology. Perhaps as a new user and relatively new company to the 350Z community you might consider the term "tread lightly". I know of at least one US based performance company whose technical documentation is at the LEAST on par with yours and in some instances superior (albeit for a different product). They also make a water injection system and anyone would tell you their documentation is anything but lacking.
Old Aug 30, 2007 | 01:56 PM
cmtech1's Avatar
cmtech1
I am referring to US methanol water injection companies, I thought that was obvious.
There are many US based performance companies that have greater documentation than us, I dont dis-agree. There are US companies that have insane technology and you cant compare that industry to ours. Im referring to the market that we serve in, methanol/water injection. all companies today do are throw together a basic controller and call it the day. They simply throw up a website and a picture of the product.
Anyway, I posted this to the original poster simply to ask why our documentation is "non existant", not to get into a pissing contest with you. If I am too blunt or said something to **** you off, I am honestly sorry you feel that way. I dont want to argue on this point. I stated my opinion on other US based methanol injection companies, you may not agree, I'll give you that you have the right to feel that way. I am just greatful for everyone that has supported our product and want to make any improvements that we can to help further the product.
CM
Old Aug 30, 2007 | 03:22 PM
MIAPLAYA's Avatar
MIAPLAYA
CM
Clearly I couldn't disagree more with your broad assessment of the countless compaines out there in the US that produce water/methanol injection systems. While I'll drop it as to not ruin this thread any further but will close by saying before you make assumptions and broad statements on this forum you may want to rethink your wording. You certainly won't gain any customers here like that. I guess I'll just move on with my "thrown together" Spearco WIS.
Old Sep 12, 2007 | 04:55 AM
cmtech1's Avatar
cmtech1
You are entitled to your opinion, everyone has different standards, whats great or acceptable for someone, is unacceptable for someone else. I'm glad you like your system.
Good luck!
CM
