TT vs ST dyno overlay
First off I want to say that I found an older thread about this and it got kinda out of hand. I in no way want to have a "this kit is better then this kit debate". All I want to ask is if anyone has a dyno overlay of a TT car and a ST car that are very close to the same WHP. I am curious to see the power differences at certain rpms.
Originally Posted by georgec
if both systems are tuned thoroughly then the twin turbo will have more power/torque in the low, mid and high rpm range, that's a no brainer.
Originally Posted by MIAPLAYA
I'd say that depends on several other factors.
At the same boost pressure a pair of smaller twins on the VQ engine will easily have the superior power/torque curve as a large single won't make peak boost until around 3800 - 4000 rpm.
'll say it again, theres a reason many high hp cars switch to a large single over twins...
yeah I'd think that with 2 banks on the engine a pro high hp race car you'd rather have 2 big turbos instead of 1 big turbo.. Then each bank has it's own intake, turbo, exhaust manifold, and exhaust piping
for the TT kits on the Z, because the turbos are slightly smaller than on the ST kits, they simply spool up faster and ultimately give you more high hp potential than any of the ST kits - unless you upgrade the blower on the ST kits or something
I have one of these, but it might rub some people the wrong way if I post it. You can PM me if you're really interested...
It has a lot to do with the tuning and boost control, but BOTH setups are very capable of putting down power where you want it. Besides, once you go for huge power, you will have lag with the TT's anyway, as you're now pushing each [upgraded] turbo with only 3 cylinders each, wheras with a single you're pushing the turbo with all 6... so go figure.
And to the above post, it's real funny that he says you won't make peak boost until 3800-4000 rpms. I'm pretty sure my ST setup (and other brands) are making full boost WELL before that.
I would much rather have a big single so I can make 200TQ till 5000rpms then 800whp from 5000rpms to 6000 rpms..
I just love seeing 900 hp Supra's that build power at 6000 rpms when redline is 7000 rpms
Yeah man look at all that lag Im getting, Im only making 400TQ at 2500rpms and 560Tq at 3800rpms, then it holds 540tq till reline
Fight Fight
