Headgames/Cosworth Heads - Comparisons?
Old Jul 7, 2006 | 06:53 AM
BrianLG35C's Avatar
BrianLG35C
Question Headgames/Cosworth Heads - Comparisons?
Considering one these heads for my build, has anyone compared flow or build quality?
Old Jul 7, 2006 | 07:11 AM
Alberto's Avatar
Alberto
Cranky FI Owner
There was a post in the general Performance section that turned into a debate/ semi informative thread. Pics and some flow chart #'s were posted. Also opinions on both sets of heads. May wanna check it out....
Old Jul 7, 2006 | 07:14 AM
BrianLG35C's Avatar
BrianLG35C
Got it, thanks.
Old Jul 7, 2006 | 07:26 AM
Philthy's Avatar
Philthy
Boost Junkie
Biggest advantage with going with Headgames is you have flexibility with Dave - NA Head - no problem, FI Street Heads - sure thing, or full FI Race Heads - you got it...
I haven't seen much real world data on the Cosworth heads yet, but they look like an NA head that would work ok for mild FI as well...
Old Jul 7, 2006 | 07:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
^ +1 from what Ive read. If I were going with a set of heads Id go with Dave's heads...
Old Jul 7, 2006 | 07:47 AM
BrianLG35C's Avatar
BrianLG35C
Thanks, I'm leaning toward heads over sleeves for my build. I understand the increased flow will obviously lower internal stress and will make the motor so much more efficient. Which means I can get a lot more hp/torque from less boost. This will make my new motor happy.
Old Jul 7, 2006 | 10:15 AM
Nismo350ZRT's Avatar
Nismo350ZRT
That's exactly what I'm thinking too. I'd rather spend $2-3k on the heads than sleeves. MRC's numbers are just awesome with the HeadGames heads.
Old Jul 7, 2006 | 10:26 AM
vq35carel's Avatar
vq35carel
I will check on the cosworth heads and get all the specs. I believe they just came out with a FI set of heads. I will keep you guys posted or pm me.
Old Jul 7, 2006 | 11:22 AM
BrianLG35C's Avatar
BrianLG35C
Right, why sleeve when you can get this much power/torque at such a lower psi.
Old Jul 7, 2006 | 11:28 AM
rednezz's Avatar
rednezz
On a customer service stand point Cosworth is very tight with information. Don't know why since I already bought the dang heads.
Old Jul 7, 2006 | 11:30 AM
BrianLG35C's Avatar
BrianLG35C
Post some numbers asap!
Old Jul 7, 2006 | 12:01 PM
rednezz's Avatar
rednezz
The heads are 58cc's and below is the flow chart from cosworth. Don't know much more than that. The valve train is Ferrea oversized valves with titanium retainers. I got this info from Ferrea but never could confirm with Cosworth.
Intake Valve = 52 grams
Exhaust Valve = 47 grams
Outer Spring ID = 20.8 mm
Outer Spring OD = 28 mm
Inner Spring ID = 15.88 mm
Inner Spring OD = 20.8 mm
Attached Thumbnails Headgames/Cosworth Heads - Comparisons?-coshead-flow-data.jpg
Old Jul 7, 2006 | 12:02 PM
plumpzz's Avatar
plumpzz
Another big advantage is how easy is it to get support from Dave? If you want support for Cosworth, you have to go through w/ a large international corperation. If you want support w/ Daves heads, call dave..
Ive learned that customer support is crucial for any aftermarket item, epsecially ones that cost more than 4 grand.. Also, remember that Daves shop is US based.
Old Jul 7, 2006 | 12:14 PM
rednezz's Avatar
rednezz
+1
Cosworth may have good heads (have yet to find out since I haven't finished my motor) but as of right now its hard to get solid info.
Old Jul 7, 2006 | 01:22 PM
BrianLG35C's Avatar
BrianLG35C
+1
Can you give a little more details on your build? When do you expect it to be finished?
Old Jul 7, 2006 | 01:23 PM
BrianLG35C's Avatar
BrianLG35C
Good point!
Old Jul 7, 2006 | 02:14 PM
rednezz's Avatar
rednezz
I am doing a NA high compression build with Cosworth heads. I was going to use Cosworth 11 to 1 pistons, and carillo rods and get some cams ground for me with 12.1 mm lift. Now I going with cams with 11.5 mm lift instead.
I probably will not have my motor ready until fall. I orginally wanted to have it built by first week of August. However, I started kicking around the idea of using the VQ40DE block and crank and replacing the pistons and rods. .
Old Jul 7, 2006 | 05:04 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
You do know the block on the VQ40 is taller right?? It might not even fit under the hood of a 350Z with the intake manifolds bolted up.
Old Jul 7, 2006 | 05:30 PM
dscheers's Avatar
dscheers
My engine should be ready end of month with Cosworth heads, 14 psi of boost from a Procharger and water methanol injection.
Danny
Old Jul 9, 2006 | 10:31 AM
BrianLG35C's Avatar
BrianLG35C
Just so I'm clear, "FI Gods"...why wouldn't you spend the budgeted amount for a build on new heads with L-19 or 1/2" studs instead of sleeves? You can run much lower psi for the same whp which lessens motor stress/headlift risk, right? What's the downside?
