It's *finally* Begun.. Engine Build!
Old Jul 13, 2006 | 12:35 PM
THE TECH's Avatar
THE TECH
I wish I had that kind of money to burn!
Old Jul 13, 2006 | 03:16 PM
EM-EFER's Avatar
EM-EFER
I figured with all the dealer mark up you would have 50 VQ's lying around
Old Jul 13, 2006 | 07:32 PM
aaronlosey's Avatar
aaronlosey
from one drift turbo z to another, i'm excited for you! i've been putting off my engine build now since i can't seem to kill my engine. its been through way more than 100 tires, 1.6 bar of accidental boost ( on race gas ), and tons of abuse. 1000's of clutch kicks! i've been running 8psi consistantly for quite some time now, sometimes jumping all the way up to 10.5.
the vq motor is far stronger than everyone gives it credit for. too many people over look tuning.
Old Jul 14, 2006 | 08:05 AM
roncfpz's Avatar
roncfpz
Good luck with the build. And thanks for using the stock block as a "sacrificial lamb" to the FI gods. Should be interesting to read what happens. Also, def give strong consideration to using the HKS headgasket. Just a little more "insurance."
Old Jul 14, 2006 | 11:38 AM
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by Chebosto
as far head gasket- with my intentions for a reliable and decent power build.. i'll try to make due with stock head gasket... but i do hear that HKS head gasket is now available- i need to read up on it more.
Cheston, I put up an article on the HKS headgaskets right here: http://www.cj-motorsports.com/headgaskets.htm
That should give you all the information and specs you might need. Its one of MANY tech articles i have been meaning to put up on the page but I just havent had time to do them all. I figured the HKS headgasket information would be worth sharing immediately.
Old Jul 14, 2006 | 02:42 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
We just got two in stock, if anyone needs them. http://www.forgedperformance.com/sto...cat=276&page=1
Only time will tell, but it looks/feels like an excellent design.
Old Jul 14, 2006 | 03:04 PM
Chebosto's Avatar
Chebosto
Charles-
thanks for much for that article-.. very very informative- i've called my HKS contacts here in So Cal, trying to procure one here locally..
custom head bolts, eh?... oh boy. more $$...
Old Jul 19, 2006 | 02:18 PM
Chebosto's Avatar
Chebosto
*update*
woot. picked up the HKS headgasket today @ noon. i'll post some picts up.. but yea. looks alot beefier than stock one.
i <3 HKS!
Old Jul 19, 2006 | 08:08 PM
Chebosto's Avatar
Chebosto
*** Special thanks to Brandon & Will @ HKS for the support ***
Freelancin' for Jtuned has its privledges ...
Old Jul 19, 2006 | 09:22 PM
JETPILOT's Avatar
JETPILOT
HKS Head Gaskets.....
I'm going with those....
Respect
JET
Old Jul 19, 2006 | 09:35 PM
daytona350z's Avatar
daytona350z
yay! go cheston!!
good luck with the stock motor. im curious to see the results. and cant wait to see the results of the new motor. get that thing in before drift day so we can see you drift the irwindale bank
Old Jul 20, 2006 | 03:39 AM
gringott's Avatar
gringott
Cheston, particularly keep us updated on how those pink injectors work out.
Old Jul 24, 2006 | 04:40 PM
Chebosto's Avatar
Chebosto
*Update*
ok. so we're testing the stock engine's integrity right now and getting new A/F maps for different boost pressures.
we've completed 7, 7.5,8,8.5, and 9 psi boost levels with this stock PE kit and reflashing of the ECU.. looks like i'm almost to the point of maxing out the PE's stock 380CCs..
and for some reason my HKS EVC is having trouble holding boost to redline, it'll hit the desired boost level and then drop back off- grrr....
my Torque #s are way higher than HP. which is good- thats what i want.... but now the next issue is the MAF. e're looking into Q45/ Titan MAFs for the build up.... more updates later. we might be ditching the turbo intake piping and going a more custom route, as well as the pipe into the throttle body--
Old Jul 24, 2006 | 04:49 PM
doug's Avatar
doug
i guess most of you guys don't understand what sponsorship means
Old Jul 24, 2006 | 06:25 PM
Chebosto's Avatar
Chebosto
More update..
solved the mysterious boost pressure loss.. it's my intercooler/piping after the turbos.
we tapped a hose fitting into the turbo-exit pipe on the passenger side and did a dyno run, looks like boost is being sustained..and not dying off like it was before.. we're going to resign the turbo outlet pipe that goes into the intercooler (you were right Gurgen/Charles)
hopefully this will cure the sustained boost goblins...
did about 15 runs on the dyno today. time to call it quits.. more updates when i get em...
Old Jul 24, 2006 | 08:03 PM
03Z33's Avatar
03Z33
nice work! I think you'll have the highest HP in all of Club BOB
let me know if you need any help with the MAF issue... I can lend you the following for testing as needed:
Split Second MAF clamp (adjustable to whatever voltage you need)
MAF housings (3.125, 3.25, and 3.5")
or you can always re-tune with a nice sized resistor in-line I would log voltage and see where you're maxing out, let me know if you need help sizing the resistor.
Old Jul 24, 2006 | 09:45 PM
mraturbo's Avatar
mraturbo
Nice...
When?
M
Old Jul 24, 2006 | 11:02 PM
  #38
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Very exciting stuff cheston!! Can't wait to see the finished result!
Forgot to mention i have spare VQ--
Somehow I picture it sitting in your bedroom on a makeshift saw-horse
Old Jul 25, 2006 | 04:46 AM
  #39
Alberto's Avatar
Alberto
Cranky FI Owner
Awesome update. Can you tell us how much power you were making at 9psi? Also what exhaust do you run? Usually if you have much higher TQ numbers than hp your exhaust is a restriction....
Old Jul 25, 2006 | 08:39 AM
  #40
gringott's Avatar
gringott
More update..
When I had my PE tuned at AAM, it also had trouble holding sustained boost pressure - part of the problem, I am sure, was a small hole in the connector to the intercooler, fixed with a new (better quality) silicon connector. Unfortuately, this was discovered very late in the day, and there was no time to dyno again to check if this was the only problem. But it does seem to me (as a novice in FI) that the PE kit could have a little better plumbing setup - esp. the final collector before the IC. And the silicon connectors are, IMO, rather thin and the opposite of robust.
