It's *finally* Begun.. Engine Build!
Old Jul 25, 2006 | 09:18 AM
  #41
Chebosto's Avatar
Chebosto
Originally Posted by Alberto
Usually if you have much higher TQ numbers than hp your exhaust is a restriction....
yea. tell me about it.. i'm still on stock Cats, but with JIC ypipe & RSR...
i'll be selling this setup for a new exhaust system and custom cats...
the load-based chassis dyno we're using is from Superflow. i dont know how much difference the settings are from Dynojet. but we've been hearing 10-15% reading less than dynojet, even with that correction factor... my HP #s are pretty disappointing, but everything on that dyno is low!!! built motor Greddy TT kit dyno'd and only like high 300s.. we think it might be a calibration figure for the car weight that's in the software that we have to change. plus we're not quite sure the %difference bwtn the Superflow and Dynojet might be different as the rollers spin faster at higher speeds..... but for tuning purposes, it's great.. takes much more data points over a longer time set than Dynojet. So for the time being, we're going off the delta in the different runs for power/torque settings w/ different AFRs...
Old Jul 25, 2006 | 10:38 AM
  #42
Brian@Performance's Avatar
Brian@Performance
Performance Nissan
Stock cats! I wouldn't worry too much about the y-pipe and the exhaust then. We've found what part of your exhaust is restrictive.
Old Aug 18, 2006 | 09:04 AM
  #43
Chebosto's Avatar
Chebosto
wow. late update, i guess....
the Crank, rods and pistons have been assembled in the engine.. to my amazement, Howard @ Technosquare had sent out my crank, bearings, and some other engine components to get a metal surface treatment called "WPC"
here's the website:
www.wpctreatment.com
supposedly, they treat the surface with highspeed medium (silica?) and it dimples the surface to create these resevoirs that will retain oil better, to reduce friction & improve durability.
the marketing on the website said they've used it extensively @ LeMans (???) and Howard said they started doing this to race cars in Japan..
truth is i have Zero knowledge of this... i guess i'lll be reading up on it... i think it's similar to Shot Peening...
more updates later..
Old Aug 18, 2006 | 09:14 AM
  #44
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
here's the website:
Similar to shot peening is correct. Most aftermarket rods are shot peaned. It removed any surface imperfections, to strengthen the material, and prevent the potential for crack or deformation propogation.
Thanks for keeping us posted.
Old Aug 18, 2006 | 09:16 AM
  #45
Chebosto's Avatar
Chebosto
but have you ever heard of it being done to the whole crank?
Old Aug 18, 2006 | 10:38 AM
  #46
Sharif@Forged
Forged Performance
Yup. It can be done to just about anything. A little overkill never hurt.
Glad they are taking nice care of your car.
Old Aug 18, 2006 | 11:43 AM
  #47
NoLimit's Avatar
NoLimit
^similar to shot peening, ... but better for sure!!
Old Aug 18, 2006 | 01:12 PM
  #48
Zilvia's Avatar
Zilvia
dam that beast is gonna be killa..............i so jealous
For now we have put off the install of out PE till our friend gets back to new(back surgey).........so i sit and wait for December to come
Old Aug 20, 2006 | 08:37 AM
  #49
mraturbo's Avatar
mraturbo
Chest,
Are you going to the Drift Event at Irwindale?
M
Old Aug 20, 2006 | 09:52 AM
  #50
Chebosto's Avatar
Chebosto
Originally Posted by mraturbo
Chest,
M
unfortunately. my car won't be done until sept probably.. i'm getting the turbo piping redone for a slightly larger diameter.. i wish i could go drifting with you guys
Old Aug 20, 2006 | 10:00 AM
  #51
gringott's Avatar
gringott
Do you have a plan to make something better than this while still using our stock intercooler?
Attached Thumbnails It's *finally* Begun.. Engine Build!-intercoolerypipela3.jpg
Old Aug 20, 2006 | 04:53 PM
  #52
Chebosto's Avatar
Chebosto
yessir-
probably going to use the original prototype design Richey made and make it a much wider collector:
if not, i might got the way KTaylor did and go with a custom endtank to the original ARC intercooler and just make two inlets.
Old Aug 20, 2006 | 05:32 PM
  #53
KTaylor's Avatar
KTaylor
yeah, that peice looks good^ and looks to be better flowing to. Im looking foward to the new numbers becuase that PE collector pipe was very restrictive. do a before and after dyno if you can. i wish i had to compare but i have a bunch of other changes so i wont be able to tell what just changing that out did as far as gains.
Old Sep 22, 2006 | 05:33 PM
  #54
Chebosto's Avatar
Chebosto
updates:
engine done (finally. sheesh) but.. not yet installed...
cool pict tho. my first! :0
...and some of the prebuild tear down picts:
goodies :
(standard.. non L19)
Old Sep 22, 2006 | 06:28 PM
  #55
Gumpdriver's Avatar
Gumpdriver
LOL JDM in side everyone.
Old Sep 25, 2006 | 08:01 AM
  #56
Brian@Performance
Performance Nissan
Commonnnnnnnn. Tell Howard to hurry up so I can get a ride already.
Old Sep 25, 2006 | 09:37 AM
  #57
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
updates:
LOL I saw this picture last night right before I fell asleep, and then after falling asleep I had a dream you told me that the reason the engine bay was empty was that you're converting to a rear engine setup
Old Sep 25, 2006 | 10:12 AM
  #58
Chebosto's Avatar
Chebosto
i dont know whats more disturbing.. u reaming about me, or me actually wanting to spend more money for a rear engine conversion.
Old Sep 25, 2006 | 10:37 AM
  #59
chimmike's Avatar
chimmike
you're going with the regular ARP head studs as well?
I'm considering having them Cryo treated for added strength in order to be able to torque 'em down another 5ft-lbs or so.....
Old Sep 25, 2006 | 10:45 AM
  #60
Enron Exec's Avatar
Enron Exec
IMO, the only reason you cant torque the standard ARP head studs any harder is because they might start tearing through the aluminum block's threads. 5 ft-lbs over what Nissan reccomends should be fine. You dont need to cyro the ARP studs. If your gonna torque them any more beyond that, then you will need larger threads from the L19 ARP studs to contact the larger threads in the retapped block.
