V-mount intercooler/radiator
Old Jul 16, 2006 | 02:24 AM
atchernyshev's Avatar
atchernyshev
Question V-mount intercooler/radiator
Team,
can you give recomendation about V-mount intercooler/radiator kit for 350Z
Andrew
Old Jul 16, 2006 | 05:26 AM
k3silk's Avatar
k3silk
do you mean the intercoolers that come in the jwt kit?
Old Jul 16, 2006 | 05:28 AM
k3silk's Avatar
k3silk
that is the only kit i have seen with V mount, although you can always get two intercoolers and weld them together?
Old Jul 16, 2006 | 05:36 AM
meatbag's Avatar
meatbag
This is a v-mount setup.
I was trying to do this, but wasnt happy with how things were going with the fab shop so its something i might try to persue later on.
The easiest thing to do would be to trim the factory core/radiator support out of the way so your headlight mounts and crap all stays in place. Then you can try something like Signal did in that pic or build a tube frame to hold all of your components. But unless you have an longnose bumper or something you really cant fit that much of a bigger radiator or intercooler in the car, but the effects of having air pass through each one (radiator, intercooler) on there own paths provides better cooling then have the air get heated up by the IC first then going through the rad.
Attached Thumbnails V-mount intercooler/radiator-vmount.jpg
Old Jul 16, 2006 | 05:59 AM
chimmike's Avatar
chimmike
problem with Vmounting, is each time it the air directly hits the rad, and it's angled, it slows down the airflow because it has to make a turn. then while slowing down, gives it more time to heat up before it hits the IC.......just my observation. That and it's entirely too complicated for a stock motor setup.
Old Jul 16, 2006 | 06:32 AM
meatbag's Avatar
meatbag
Why would the air flow through the radiator then the IC??? Thats the whole point of the vmount setup so each one has its own airflow stream and it doesnt flow through the other afterwards.
Attached Thumbnails V-mount intercooler/radiator-vmount2.jpg
Old Jul 16, 2006 | 06:47 AM
chimmike's Avatar
chimmike
well, if you can make a complicated setup like that work in the Z without spending a fortune, by all means.
Old Jul 16, 2006 | 12:19 PM
atchernyshev
like Signal Auto
Old Jul 16, 2006 | 12:21 PM
atchernyshev
yes .. i'm looking for bolt in kit
Old Jul 16, 2006 | 12:23 PM
chimmike's Avatar
chimmike
there's no such thing yet, good luck.
Old Jul 16, 2006 | 06:19 PM
k3silk's Avatar
k3silk
oh my bad didnt know that sorry.
Old Jul 16, 2006 | 08:27 PM
Oleg's Avatar
Oleg
Team,
Andrew
Esche odna ne samaya umnaya idea. Otkroi kapot i zaglyani tudyt', tam negde pernut'. Dlya etogo pridetc'sa razbirat' i perestraivat' ves' peredok i odevat' udlinenniy bamper, kotoriy sam po sebe budet smtret'sa tupo bez polnogo komplkta. Signal auto, kotoriy eto sdelal zamenil nash dvizhok na boleye kompaktniy dvigatel' iz Nissan Silvia. Pover' mne na slovo, lyuboy iz suschestvuyuschih forsazhnyh komplektov ne budet sozdavat' usloviya pri kotoryh promezhutochniy ohladitel' zablokiruyet radiator. Esli ty gonyaesh' seryozno, to kupi bol'shiy radiator is vse.
Same this in English for others to comment on:
Another not so bright idea. Open your hood and look inside, there is no room to fart in there. In order to accomplish this you'll have to take apart and re-engineer the whole front of the car, and then add a long-nose bumper, which will look dumb without the full kit. Signal auto, that pulled this off, replaced our engine with a smaller one from a Nissan Silvia. Take my word for it, any of the existing FI kits will not create a condition at which your radiator will be blocked by the intercooler. If you are racing seriously, get a bigger radiator.
Old Jul 17, 2006 | 11:26 AM
atchernyshev
spasibo za info. kakoi radiator porekovenduesh ?
Same in English:
thank you for info. please recomend me radiator vendor ...
Old Jul 17, 2006 | 11:39 AM
Oleg's Avatar
Oleg
Same in English:
A lot of people are using Koyo, but it requires extra work to install it. There are radiators from Power Enterprise, Greddy, ARC, but they cost a lot.
If I were you, I'd keep the stock radiator initially and see if any overheating issues before spending more money on a upgrade.
The stock radiator is pretty large, and Moscow's climate is pretty cool. Unless you have plans to race in on tracks for prolonged time periods, you stock radiator should be adequate.
Ksati, esli ne tyazhelo, sdelay foto mashini na fone Kremlya ili hrama Vasilia Blazhenogo. Vsegda hotel uvidet' etu kartinku...
Old Jul 17, 2006 | 12:02 PM
atchernyshev
u menia poka net 350z ... prosto obdumivau proekt
atchernyshev
Jul 18, 2006 03:33 PM
atchernyshev
Jul 16, 2006 12:22 PM
