made some power... aps tt 18psi, VERY conservative timing
Old Jul 26, 2006 | 07:42 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Exclamation made some power... aps tt 18psi, VERY conservative timing
well, here it is, aps tt, tuned with the UTEC with very conservative timing
I changed my mind/goals on what I wanted out of my car, so after many hours of hard work, I pulled the motor, changed the cams (Scott's Performance) and swapped turbo kits....wehhhhh!
running 101 octane and 50/50 water methanol injection
This is the LOW BOOST setting, my boost controller was acting up, so I stopped at 18psi...I will run a higher boost number od 22-23psi and see what we can do
94 degrees out as well!
dynojet with no smoothing...pretty damn smooth graph
thanks to Sharif and Sam for your on phone guidance and tutoring of the UTEC!!!
-TODD
Old Jul 26, 2006 | 07:45 PM
Peking's Avatar
Peking
Geebus, congrats man. If I felt 600 WHP I might just pee my pants a little
Jonathan
Old Jul 26, 2006 | 07:50 PM
bigbri's Avatar
bigbri
Good sh it man how is the car running in the colder weather???? You happy with the swap in kits??
Old Jul 26, 2006 | 07:51 PM
AmyCroft's Avatar
AmyCroft
Smile Great AFRatio
Excelent results..
Just fantastic..
When the tempature comes down.. Expect the results to increase..
That UTEC is doing a great job.
Cheers Amy -
Old Jul 26, 2006 | 07:54 PM
atar350's Avatar
atar350
Awesome!
Old Jul 26, 2006 | 09:16 PM
mchapman's Avatar
mchapman
Very nice, how is the response compared to your last setup?
Old Jul 26, 2006 | 09:22 PM
JisNis's Avatar
JisNis
Congrats on your 600+ hp. Get some vids up. I hardly see anyone with that much HP record some spirited driving.
Old Jul 26, 2006 | 09:25 PM
taurran's Avatar
taurran
Nice, Todd!
If you don't mind me asking, why did you swap turbo kits?
Old Jul 26, 2006 | 09:36 PM
absolutg's Avatar
absolutg
wow, nice A/F ratios ... looks like you have more room up top
Old Jul 26, 2006 | 09:38 PM
taurran's Avatar
taurran
Yeah, one of the better afr curves I've seen.
Old Jul 26, 2006 | 10:01 PM
Goerge@GTMotors's Avatar
Goerge@GTMotors
Thumbs up
good job todd
sam
Old Jul 26, 2006 | 10:21 PM
Juztin's Avatar
Juztin
awsome numbers - i'll have to swing by sometime when I'm back in burque. That thing has to be a monster on the highway. Congrats!
Old Jul 26, 2006 | 11:31 PM
JeffesonM's Avatar
JeffesonM
nice numbers... what plenum?
Old Jul 27, 2006 | 01:21 AM
Gman2004's Avatar
Gman2004
That's insane! I can't wait to see what you get with 23lbs. Congrats!
Old Jul 27, 2006 | 03:23 AM
mistaboosta's Avatar
mistaboosta
how much timing are you talking about when saying very conservative?
No offense but conservative is a very changeable term from one person to other.
Old Jul 27, 2006 | 04:55 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Talking
sure, i understand...
to give you an idea...I originally tuned with 11 degrees of timing advance follwoing the torque peak, carried that out to redline...
I made 580whp and around 620tq...I added 1 degree of timing, so a 12 degree advance and picked up 20 hp and 20tq....
Because of the temps and time I had already spent on the dyno, I decided to finish this process after I figure my boost controller out, I will lean out the AFR to approx 11.8:1 (it richened up on the street, more load, richer afr)...and I plan to run approx 14-15 degrees of timing up top (I am running 101 octane and methanol injection) ...
so, with this same boost, I should be able to make about 40 more hp and tq...with 22-23psi, I will be well into 700's
-TODD
Old Jul 27, 2006 | 04:56 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
plenum spacer...possibly with a more aggressive plenum and more timing towards redline, the power may not drop off...
Old Jul 27, 2006 | 04:58 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by taurran
Nice, Todd!
I upgraded the greddy turbos to make tons of peak power...I was originally planning on 700-800 with room to go, I chnaged my mind, don't want to go that high with the power, the situations worked out and I picked up an aps kit
Old Jul 27, 2006 | 04:59 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
lots of torque, builds very quickly, as you can see in the graph, over 220w tq in lessthan 1000rpm's!!!
Old Jul 27, 2006 | 05:00 AM
BrianLG35C's Avatar
BrianLG35C
Nice , is this the extreme kit?
