voltage on inline fuel pump on vortech??
Old Aug 27, 2006 | 05:18 PM
zr05's Avatar
zr05
Default voltage on inline fuel pump on vortech??
Does anybody know how many volts the inline fuel pump on the vortech kits runs on?????
Old Aug 27, 2006 | 05:58 PM
booger's Avatar
booger
Might show it in the manual
Old Aug 27, 2006 | 06:01 PM
zr05's Avatar
zr05
no it doesn't but it seems that the fuel pump isnt turning on, and everything is hooked up corectly.
Old Aug 27, 2006 | 06:52 PM
booger's Avatar
booger
Is this on a new kit install ? Used kit ? Your settings in the SS box may not be right . The settings need to be set up right for it to come on at a set rpm and or boost setting
Old Aug 27, 2006 | 07:03 PM
zr05's Avatar
zr05
this is a used kit install. bought from GMZ
Old Aug 27, 2006 | 07:17 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The pump runs alternator voltage (switch power)...12-14.5 volts. It is triggered on and off by the Split Second box.
Old Aug 28, 2006 | 03:29 AM
GMZ's Avatar
GMZ
Justin do you have a fuel pressure gauge?
Old Aug 28, 2006 | 03:34 AM
Eazzy's Avatar
Eazzy
Yep --Pressure is not determained by voltage but it HAS to have at least 12 Volts
Old Aug 28, 2006 | 04:01 AM
zr05's Avatar
zr05
no i do not have a fuel pressure gauge, but seems that there is no voltage going to the pump which could be why its runnning so lean. before the boost comes on below 4000 rpms the a/f is in the 10's, and after 5000 it runs lean.
Old Aug 28, 2006 | 04:30 AM
booger's Avatar
booger
I think I remember some one had the wires mixed up going to the pump . I would check that first . There also is a inline fuse...check that to.
kyin
Oct 15, 2015 05:54 AM
