TN Compressor Discharge leak...Help Pls!!!
Old Aug 30, 2006 | 04:51 AM
Midnyte's Avatar
Midnyte
Default TN Compressor Discharge leak...Help Pls!!!
I've had my TN kit in my daily driver for close to about 9-10 months now with no problems until now. I'm sure its minor - but I need advice on how to fix it if anyone else has come accross it. Normally my vac shows ~20-~22 but I noticed yesterday that it was showing 18-19. When I got home from work I checked all the connections and noticed that the rubber coupling from the turbo compressor discharge outlet to the pipe leading to the intercooler was rubbing on the frame that runs allong the outside of the car parrallell to the driver side headlight. It looks like that support has started to rub through. Has anyone else had that problem? I know I'm going to need to order anther coupler, but has anyone had to trim that support...or at least had any luck trying to bend it away from the compressor?
Thanks
-Blaise
Old Aug 30, 2006 | 04:59 AM
chimmike's Avatar
chimmike
it's not really any sort of structural support. I took a dremel and cut mine pretty much out. I've got to go back and finely cut it, but yeah, I did it, and my coupler finally stopped popping off the compressor outlet, haha.
Old Aug 30, 2006 | 07:29 AM
Z PHAT Z's Avatar
Z PHAT Z
^^^I also had to do mine due to installation difficulty. It's so tight there anyway. Good luck with the fix.
Old Aug 30, 2006 | 07:33 AM
disturbed2483's Avatar
disturbed2483
i had to cut a good protion of mine out.
Old Aug 30, 2006 | 10:35 AM
Midnyte's Avatar
Midnyte
Thanks guys! I'll cut some breathing room. I just wanted to make sure that it was cool to do.
As always - I appreciate the help.
-B
Old Aug 30, 2006 | 10:44 AM
MIAPLAYA's Avatar
MIAPLAYA
Keep in mind the warranty covers the couplers too! Call up customer support at 805-581-0333 and they will send you a new one.
Old Aug 30, 2006 | 12:12 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Mine also rubbed, but I took care of it. Good luck to you, TN will take care of you.
Old Aug 30, 2006 | 01:54 PM
taurran's Avatar
taurran
It seems I'm the only one that hasn't had an issue with it rubbing. I'll double check it the next chance I get.
Old Aug 31, 2006 | 06:35 AM
MIAPLAYA's Avatar
MIAPLAYA
Mine hasn't either
Old Aug 31, 2006 | 07:19 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
gonna check mine now! AFAIK no issues with that to date.
Old Aug 31, 2006 | 07:33 AM
Midnyte's Avatar
Midnyte
Just got off the phone with them. Their sending the part under warranty. They were EXTREMELY easy to deal with. Top notch customer service.
-Blaise
Old Aug 31, 2006 | 07:39 AM
MIAPLAYA's Avatar
MIAPLAYA
-Blaise
Glad they took care of you
Old Sep 1, 2006 | 12:00 PM
Three5oZee's Avatar
Three5oZee
...hmmm, i havent been here in a while..checking up on some of the TN threads... I havent had that problem either. Good luck with that one.. sholdnt cause any major issues after repair of course.
Old Dec 3, 2006 | 06:54 PM
hr2burn's Avatar
hr2burn
For whatever it's worth, I thought I was gonna have to cut that brace as well. Turns out (forgive me if this is old news!) Loosen those nuts where the polished compressor meets a gold ring and turn the turbo out of harms way.
Sean
Old Dec 4, 2006 | 05:19 AM
QuadCam's Avatar
QuadCam
Sean
i believe that's called "reclocking" the turbo.
Old Dec 4, 2006 | 05:23 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
-Blaise
I love seeeing posts like this unlike the other threads starting rumors that are false.
Old Dec 4, 2006 | 06:23 AM
MIAPLAYA's Avatar
MIAPLAYA
It is indeed
Old Dec 4, 2006 | 10:32 AM
QuadCam's Avatar
QuadCam
Ed,
you guys have always been good to deal with. fortunately, I have not had anything major...i needed a new V-band clamp and Ed took care fo me.
thanks!
Old Dec 4, 2006 | 11:00 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Ed,
thanks!
Anytime bro you know how to contact me bro
OdesiTT
Sep 30, 2015 10:47 AM
