Highway driving with vortech
Old Nov 5, 2006 | 02:51 PM
xav_350z's Avatar
xav_350z
Originally Posted by DMK
I'm thinking of adjusting it within the next hour. So, I should tighten the bov bolt so that there are 7 threads showing from the end of the bolt to the nut?
that's what i did...
Old Nov 5, 2006 | 05:06 PM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
OK - this will lay all your questions to rest:
Go here
http://www.gofastbits.com.au/index.p...tion=faqs_bovs
Rick
Old Nov 5, 2006 | 06:37 PM
Barzten1's Avatar
Barzten1
Originally Posted by 617G
+100000000000000000
Thanks booger.
I always said, Boog for Pres!
Old Nov 5, 2006 | 06:51 PM
ISMSOLUTIONS
So what is the benefit of adjusting it?
The Bypass Valve spring tension will need to be adjusted if the valve vents pressure prematurely or causes rough idling.
Old Nov 5, 2006 | 08:12 PM
DMK's Avatar
DMK
ad?
Old Nov 5, 2006 | 09:58 PM
ISMSOLUTIONS
ad?
Sorry - corrected below on original post...
Old Nov 6, 2006 | 05:04 PM
DMK's Avatar
DMK
So here is a picture of my bypass valve. I tried turning the screw not connected to the vacuum line, but it wouldn't turn any more than 5 threads. I am guessing this is the wrong screw.
Old Nov 6, 2006 | 06:54 PM
booger's Avatar
booger
yours looks to be about right
Old Nov 6, 2006 | 07:34 PM
ISMSOLUTIONS
Looks about right...you have to make sure you loosed the set nut first, then with an Allen head wrench, turn it in to about 6-7 threads showing above the nut, when tightened.
Rick
Old Nov 6, 2006 | 08:05 PM
DMK's Avatar
DMK
So I was turning the right nut? If so, allen wrench? I didn't see any opening for an allen wrench. So, I basically take off the hex nut on the bolt that is further away in the picture and then use the allen wrench where?
Ps. I would like to make the BOV close a little sooner, because I am getting a whistle when taking off from a stop every freakin time and I think it is the BOV.
Old Nov 6, 2006 | 08:07 PM
ISMSOLUTIONS
At the top of the stud, there is an allen head fitting...as if it were a screw, pretty hard to see, but it's there.
Rick
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
Mattg350z
Oct 2, 2015 06:51 AM
