APS TT WOT Issues
Old Sep 16, 2006 | 02:52 PM
  #41
captj3's Avatar
captj3
That's very intresting I have the same milage and time with the kit on my car.
Old Sep 17, 2006 | 10:45 PM
  #42
XBS's Avatar
XBS
Veteran
UPDATE:
So i put some 100 octane it was still 1/4 full so i would say its about 98 octane. it barley does the issue now, and when it does do it, its not as bad as before, tommarow im going to top off my 1/2 tank of 98 or whatever with some fresh 100 again and see what happens.....
Going to change the plugs this week as well as install the HKS DLI and HKS EVC 5 boost controller.
So what does it mean if 100 octane fixes my issue?
Thanks
-George
Old Sep 18, 2006 | 03:46 AM
  #43
BoOsTedz33TT's Avatar
BoOsTedz33TT
sounds like a clutch thats slipping...my car was doning the same
Old Sep 18, 2006 | 10:08 AM
  #44
mrtomcat's Avatar
mrtomcat
haven't thought about that but that makes sense.
Old Sep 18, 2006 | 11:07 AM
  #45
XBS's Avatar
XBS
Veteran
lol then why did the 100 octane fix the problem...lol it isnt the clutch think its the tunning or spark plugs
Old Sep 18, 2006 | 11:36 AM
  #46
mrtomcat's Avatar
mrtomcat
magic ?
Old Sep 18, 2006 | 11:37 AM
  #47
XBS's Avatar
XBS
Veteran
LOL I wish it was that simple! I need a FCON
Old Sep 21, 2006 | 12:57 PM
  #48
captj3's Avatar
captj3
xbs did the 100 octane fix your problem? If not let me know I think I found out what's wrong. That is if you and me have the same problem. I put in 110 oct today and it didn't fix anything.
Old Sep 21, 2006 | 11:15 PM
  #49
XBS's Avatar
XBS
Veteran
110/??? isnt that leaded, the 100 octane seems to solve my issue im trying to replicate it as we speak, what did u do to fix your problem? i also changed my spark plugs and installed the hks DLI
Old Sep 22, 2006 | 02:46 AM
  #50
captj3's Avatar
captj3
Yes it's leaded. I'm still working on the problem, but it seems to be pointed towards my vdc/abs systems. I've had this bug for a while. Monday my dealer will check out the system. I get a reoccurring codes 1108/1107 there was another for speed sensor. I don't remember the code #. I'll get it on monday. Everybody said it was tuning. This is why I put in the 110 oct. I have to admit the car runs real smooth and the exhaust is real cool...lol
Old Sep 22, 2006 | 11:01 AM
  #51
XBS's Avatar
XBS
Veteran
lol yea the 100 octane fixed my issues so i beleive its tunned to aggressive for 91 octane, i guess brainstorm is known for that. anyways did you get any check engine lights? i didnt, ill pull the codes for fun. Hope your problem gets resolved. im trying to scrape some cash to get a V PRO installed and tuned, that should fix everything Good luck and keep me posted!
Old Sep 25, 2006 | 02:19 AM
  #52
Julian@MRC's Avatar
Julian@MRC
The problem was most likely due to knock...Now go and performe a leakdown and compression test to be on the safe side..Once again I was right..
Old Sep 25, 2006 | 03:32 AM
  #53
captj3's Avatar
captj3
Mrc do you have any idea what could be my problem? Mine feels like the I'm hitting the rev limiter or the vdc is hitting 3500-4000 rpms at part throttle. My car doesn't even throw a code. Any help would be appreciated.
Old Sep 25, 2006 | 02:25 PM
  #54
XBS's Avatar
XBS
Veteran
going to do a compression leak down test this weekend, ive been mixing 100 and 91 to be on the safe side until i get the FCON
Old Sep 26, 2006 | 07:09 AM
  #55
Julian@MRC's Avatar
Julian@MRC
The one time we experienced similar syptoms was feul flow related,like out of fuel with a hung up float in the tank, so we thought we had fuel..
Old Sep 26, 2006 | 07:39 AM
  #56
captj3's Avatar
captj3
Just so I understand do you mean the car was running out of gas? This happens at part throttle even after I just fill the tank. Lately it's been getting worse. I know there were a few unichip harnesses that had problems, but I don't know what the issue was. APS and unichip thought it was tune related so I had my original map reinstalled it didn't make a difference. Is there anything else you can think of? Thanks
Old Sep 26, 2006 | 02:57 PM
  #57
XBS's Avatar
XBS
Veteran
Well to fix my problem im installing the HKS FCon VPRO @ GT Motorsports
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
