MIA, anybody with a TN kit?
Old Sep 12, 2006 | 02:07 PM
tig488's Avatar
tig488
Default MIA, anybody with a TN kit?
any of you guys know the turbine outlet diameter for the 60-1?
Old Sep 12, 2006 | 03:15 PM
JETPILOT's Avatar
JETPILOT
Find dimensions here.....
http://www.turboneticsinc.com/turbo_overview.htm
JET
Old Sep 12, 2006 | 03:25 PM
chimmike's Avatar
chimmike
keep in mind the 60-1 on the TN kit utilizes a 4 bolt t3 turbine housing as opposed to the typical t4 turbine housing on normal 60-1s
( I was having a discussion with a Supra guy who told me supras running 60-1's make 550-600whp so I looked into the turbines those guys were using versus ours heh)
Old Sep 12, 2006 | 04:14 PM
tig488's Avatar
tig488
thanks JET, i guess, as far as i can see, its 2.75", does that seem right.
Old Sep 12, 2006 | 05:18 PM
MIAPLAYA's Avatar
MIAPLAYA
I'll find out for you. I can tell you that the 60-1 turbo (compressor section) can come with any turbine you want. The Turbonetics kit uses a Stage V turbine wheel and housing with a .77A/R Tangential and 4 bolt discharge. I have a turbo sitting on my file cabinet at home and I'll measure it tonight.
Old Sep 12, 2006 | 05:20 PM
tig488's Avatar
tig488
thanks, just measure the exhaust turbine outlet diameter, id appreciate it.
Old Sep 12, 2006 | 05:24 PM
MIAPLAYA's Avatar
MIAPLAYA
Will do.....looking for a new turbo?
Old Sep 12, 2006 | 05:27 PM
Gumpdriver's Avatar
Gumpdriver
OK Tig, what are you thinkingof doing?
Old Sep 12, 2006 | 05:38 PM
MIAPLAYA's Avatar
MIAPLAYA
I'm thinking of a GTK turbo for him
Old Sep 12, 2006 | 05:42 PM
tig488's Avatar
tig488
lol, nah, im thinking the exhaust turbine outlet on the aps turbo is too small, its 2.5 inches for gods sake. they make a 3.5 inch downpipe and suggest their exhaust, but they have all the exhaust going into a small exhaust housing and being forced thru that 2.5 inch outlet. just doesnt make sense. im looking at getting a different exhaust housing with a 3 inch outlet and for an external wastegate.
im just want to see what size the TN turbo has.
Old Sep 12, 2006 | 05:44 PM
MIAPLAYA's Avatar
MIAPLAYA
Gotcha, I'll check that when I get home. And there my friend is the issue with internally wastegated turbos especially when you try to run a large turbo with an internal gate. What type of turbine inlet does that have? 4 bolt T4 or T3?
Old Sep 12, 2006 | 06:37 PM
tig488's Avatar
tig488
yep, 4 bolt T3 i believe.
Old Sep 13, 2006 | 07:21 AM
MIAPLAYA's Avatar
MIAPLAYA
tig apologies but last night by the time I got home I forgot to measure this for you. I will do this tonight...
Old Sep 13, 2006 | 10:34 AM
tig488's Avatar
tig488
its gotta be a turbine housing backpressure issue. i did some measuring last night, the turbine housing is .63A/R, meaning no lag, no top end. i think the turbo is the GT35/40R, the compressor wheel measures out to be a 40R wheel so it cant be that. but that A/R is terrible. they make a T3 4 bolt 3" outlet turbine housing that i might just have to buy, but it uses an external WG.
Old Sep 13, 2006 | 10:35 AM
MIAPLAYA's Avatar
MIAPLAYA
.63 seems really smalle for that much airflow. The Turbonetics uses a .77 A/R just to keep spool up times decent but could probably go bigger...You could weld a wastegate mount on the last merge pipe. Either that or try running to wastegates one at each maifold exit.
Old Sep 13, 2006 | 05:20 PM
MIAPLAYA's Avatar
MIAPLAYA
Tig its 2.75"
Old Sep 13, 2006 | 06:18 PM
tig488's Avatar
tig488
thats what i thought, thanks mia.
Old Sep 13, 2006 | 06:27 PM
MIAPLAYA's Avatar
MIAPLAYA
No worries. If you want to try a different turbo hit me up. I'm sure I can find a turbo you would want for a nice price
Old Sep 13, 2006 | 07:10 PM
tig488's Avatar
tig488
haha, i think i might just change turbine housings to the .82 AR.
Old Sep 13, 2006 | 09:28 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Tig, if you go ahead with this plan, keep us updated.. I was planning on installing external wastegate anyways.. Good luck with your R&D!
