My Built Motor with Turbonetics Is Almost Done
Old Sep 21, 2006 | 06:33 PM
driftk1d's Avatar
driftk1d
Originally Posted by doug
i hope that stage 2 kit has a healthy power band and it doesn't look like a supra dyno graph
Old Sep 21, 2006 | 06:45 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Good luck Jet. I'm anxious to hear what kind of power you make and what the curve looks like.
Old Sep 21, 2006 | 06:47 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by BriGuyMax
Is this the same famed stage 2 kit that we've been hearing about for over a year now?
I doubt its been over year. It was planned until early this year.
Old Sep 21, 2006 | 07:27 PM
taurran's Avatar
taurran
Maybe would if it used a weaksauce mitsu turbo. That's not the case, though.
Old Sep 21, 2006 | 07:30 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by JETPILOT
Let's keep out fingers crossed. Whatever power I make this combo of parts will be proven to produce X amount of power. People can build this combo and know what to expect from it. The parts list consists of Alphawerks headers, Topspeed Pro-1 Exhaust, Deatschwerks 550 injectors, and a UTEC.
TN Tuner kit: $4400
Install: $1000
Alphawerks headers: $600
Deatschwerks injectors $300
TopSpeed Pro-1 exhaust $400
UTEC $900
Tune $650
Total: $8250 for a very complete kit installed and tuned.
Still thousands less than a TT setup like the Greddy + exhaust and install.
JET
Your forgetting the $3000+ for the block your putting in to run that set-up without going boom...
Old Sep 21, 2006 | 07:35 PM
zz350zz's Avatar
zz350zz
Shhhhh i think he was trying to hide that
To the O.P. - I love me sum Sharif
Old Sep 21, 2006 | 08:41 PM
maximumsportZ's Avatar
maximumsportZ
You and your dual old fashion turbos.
Old Sep 21, 2006 | 10:02 PM
JETPILOT's Avatar
JETPILOT
All things equal.... you would have to do that for the Greddy as well.
JET
Old Sep 22, 2006 | 03:33 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Never said you wouldnt have to. Good luck man, cant wait to see the results. Regardless it will be faster and safer....
Old Sep 22, 2006 | 03:57 AM
Zlayer's Avatar
Zlayer
When your car is done, can you post up a vid. I'd love to hear your turbonetics, headers, Pro1 combo!
Old Sep 22, 2006 | 04:17 AM
doug's Avatar
doug
they work.. thats what is important
Old Sep 22, 2006 | 04:27 AM
doug's Avatar
doug
TN Tuner kit: $4400
Install: $1000
UTEC $900
Tune $650
JET
lol.. are you comparing that to a Greddy setup? i just noticed that..
if you are comparing it.. subtract the amount of money for headers and injectors.. also subtract the amount for exhaust because i will probably make the same HP if not more with a healthier powerband on a stock exhaust with a Greddy Kit.
the number 1 reason i went with a Greddy Kit was because it was the only kit todate that had the potential for the highest HP without upgrading the kit or turbo's.
Old Sep 22, 2006 | 05:09 AM
taurran's Avatar
taurran
Obviously turbo selection is exponentially more important on a single turbo setup.
Anyway... there will no reason to buy all of this 3rd party stuff if you just wait a short while longer.
And for the record, I don't recommend headers with this kit.
If you buy the turbonetics stage 1 kit and expect any more than 410whp, you may have bought the wrong kit. That is, until they finally release stage 2.
Old Sep 22, 2006 | 05:15 AM
chimmike's Avatar
chimmike
Don't listen to Craig. I'll make over 410whp on the stage 1 kit when my motor is done
Old Sep 22, 2006 | 05:20 AM
taurran's Avatar
taurran
Well, that's a given. I'm just saying that you're buying a kit that's meant for a stock car and pushing it beyond the scope of its design.
Old Sep 22, 2006 | 05:42 AM
JETPILOT's Avatar
JETPILOT
I think if your attempting 450whp then headers will be mandatory. It's only because of switching to the headers do I think i can maintain an OE powerband up to somewhere around 450whp. At some point the headers are going to be a problem as exhaust gas volume increases as power increases. We will see next week won't we.
JET
Old Sep 22, 2006 | 05:59 AM
taurran's Avatar
taurran
Well the way I see it, you're just creating bottlenecks at the end of the headers by adding them. I'm not saying you won't make good peak power, but you definitely will lose area under the curve.
Old Sep 22, 2006 | 08:27 AM
  #38
JETPILOT's Avatar
JETPILOT
Got a dyno graph of the Turbonetics with headers? making 450whp? Is this speculation or fact?
JET
Old Sep 22, 2006 | 09:24 AM
  #39
taurran's Avatar
taurran
JET
I had headers when the kit was originally installed. Swapping back to stock manifolds I lost less than 10 peak whp but made boost 700rpms earlier with a better midrange. I don't have the after graph on the same dyno as I didnt take it home that day. The car also felt much more responsive and ran smoother with the aftermarket headers, smooth enough that I would have preferred it even if I were making much less power.
I don't see it making THAT big of a difference at 450whp, but of course I may be wrong so don't get offended.
From what I remember, the crossover pipe is even more of a bottleneck with the headers installed, and on top of that you must modify (bend or narrow) the turbo downpipe to fit the aftermarket headers. This is one of the largest of my concerns with the setup. Basically what I'm getting at, is I don't think the stock manifolds act as much of a bottleneck as some other areas on the stage 1 kit, and being able to squeeze them in there just makes the others worse.
I'm looking forward to seeing your results, however. It will give us an idea of what the stage 1.5 kit may be capable of on a built motor.
Old Sep 22, 2006 | 11:40 AM
  #40
JETPILOT's Avatar
JETPILOT
No... I'm not offended. The Alphawerks are supposed to fit without any modifications at all.
JET
