My Built Motor with Turbonetics Is Almost Done
Originally Posted by MIAPLAYA
As I said. If he is running 17 PSI without a boost controller and stock injectors e should stop driving the car and check the boost signal to the wastegate.
well, i'm gonna bet he's not if Scott Performance built his motor and installed the fuel system.
well the car is still being tuned, as far as going with the larger injectors with the TN kit and what not...i would much rather wait for the stage 2 kit. From what ted told me he said the accuator is the problem its not releasing air thats why the car is boosting so much. We are still waiting on that so i guess in the mean time all i can do in the mean time is wait and ask questions with out being flamed
...although I find it hard to believe a shop like this would miss something so simple.
the line should run from the nipple on the turbo directly to the lower port on the wastegate. Maybe, they installed the fitting into the upper port of the wastegate....that'd be a problem!!!!
also, do you have the wastegate relocation pipes? installed?
My money says that is te exact problem. The boost line should be going to from the compressor outlet to the lower wastegate port (furthese from the chome top section and logo). If it is going to the upper port (closest to the logo) the wastegate is being held closed. That port is for a boost controller.
what about the wastegate relocation pipes? are those installed?
still 17 psi....something's not hooked up right or you have a broken wastegate. my vote is for "something's not hooked up right."
Originally Posted by chimmike
my vote is for "he doesn't know what the hell he's talking about and they tuned it to that" or something along those lines.
"i didnt have anything else to post,sooooo i deceided to hate
"any how, i talked to ted he said the accuator needed to be replaced so he did that, but! he said that the car can easily boost to 15psi...lets see wat happens
thanks guys for the help
orrrrrrrrr
Originally Posted by Gumpdriver
Hey Jet whats the Status on the build?
yes..any updates? are you doing anything to try to reduce backpressure between the heads and the turbo?
15psi, 350z, ahmads350zyahoocom, built, dont, downpipe, engine, fit, header, motor, nissan, recirculate, sfr, turbonetics, wastegate
