how safe is stock psi on stock block?
Old Sep 25, 2006 | 04:36 PM
deviljon's Avatar
deviljon
Default how safe is stock psi on stock block?
i couldnt find anything that specifically answered my question, so here goes... im looking to install the aps st on my 06 6mt. i decided not to build my block because of all the downtime and expenses and so on.
i believe the aps st boosts at ~9psi out the box. i do plan on pushing my car pretty hard but not very often and not at the track. how safe is it to run stock boost on the aps st on a stock block? any input would be appreciated... thanks
Jon
Old Sep 25, 2006 | 04:38 PM
chimmike's Avatar
chimmike
first thing thta comes to mind is ask that question here https://my350z.com/forum/search.php
as people have asked that exact question many times
Old Sep 25, 2006 | 04:56 PM
spracked's Avatar
spracked
As long as you get it installed and tuned at a authorized aps shop you are more than fine. MOST people who blow their motor are people exceeding 400whp and 400 lbs of torque on stock internals. You should be fine on a conservative tune.
Old Sep 25, 2006 | 05:21 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
It's all in the tune. I run my car very hard (only at the track, I dont street race). It's all in the tune!
Old Sep 25, 2006 | 05:25 PM
failsafe306's Avatar
failsafe306
Just don't go over 18psi.
Old Sep 25, 2006 | 05:33 PM
savvy's Avatar
savvy
hahaha 18 is far from stock
Old Sep 25, 2006 | 05:35 PM
eagletanggreen
Got Track!!!!!
Yeah! Try 12psi
Old Sep 25, 2006 | 05:50 PM
JETPILOT's Avatar
JETPILOT
That's not true. Sharif tuned my car and it made 410whp and 410 ft-lbs. I snapped a connecting rod. The rods are junk. So it's not ALL in the tune. However a good tune is essential but that doesn't mean a connecting rod won't walk off the job especially at high rpm's. I had my rev limiter set at OE as well. Rev up motors are beefier than no rev up motors.
JET
Old Sep 25, 2006 | 05:58 PM
Gumpdriver's Avatar
Gumpdriver
Man between .0 to 9.2.
Old Sep 25, 2006 | 06:15 PM
HoldThisForMe's Avatar
HoldThisForMe
Check out my rod pix...if i was you i would not go about 465ish whp...every motor is different tho...but you are talking stock boost...if thats all you EVER run which you wont lol you will be fine
Old Sep 25, 2006 | 06:17 PM
deviljon's Avatar
deviljon
thanks guys, im definitely looking into a conservative tune. 400 whp is probably my maximum limit.
Old Sep 25, 2006 | 06:49 PM
eagletanggreen
Got Track!!!!!
[/SIZE]
JET
If you pray every night and you eat all your vegetables, everything will be alright. You have to have faith, and believe! Just three more months.
BOOST IT! 11.5psi stock block
Old Sep 25, 2006 | 07:31 PM
JETPILOT's Avatar
JETPILOT
You have to have some fairy dust and sprinkle it on the motor. That will make it last!
JET
Old Sep 25, 2006 | 09:52 PM
MethodRN's Avatar
MethodRN
For Sale
If you plan to stay w/ unichip EMS find an APS certified dealer that can tune unichip and w/ stock boost you "should" be ok. I say this because there are no certainties when it comes to shoving more air and fuel into an engine that was not designed to have FI to begin w/. Good luck man.
Old Sep 25, 2006 | 11:18 PM
deviljon's Avatar
deviljon
has anyone ever blown their motor running less than 400 hp?
Old Sep 25, 2006 | 11:35 PM
deviljon's Avatar
deviljon
nevermind dont answer that i just did some research haha
Old Sep 26, 2006 | 03:18 AM
captj3's Avatar
captj3
Keep your torque under 400 and a good tune you should be ok. I have my kit with over 20k and still going strong on a stock block.
Old Sep 26, 2006 | 04:05 AM
k3silk's Avatar
k3silk
what kit are you running?
Old Sep 26, 2006 | 06:08 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Properly installed, an APS single T or APS TT is unlikey to break an engine at stock boost (350-370whp). out of the box, they typically run very rich, and conservatively tuned. You should be fine...but definately test it on the dyno before going nuts with the engine.
Old Sep 26, 2006 | 06:18 AM
captj3's Avatar
captj3
I'm running a APS TT
