going turbo on auto?
Old Oct 4, 2006 | 10:38 PM
350z on DUBZ's Avatar
350z on DUBZ
Default going turbo on auto?
I plan on going with a turbonetics st on my 03 auto but I wanted to know is there anything that I should look out for when buying the kit or gettin it installed?
Also does anyone have this kit on there auto or know anything else about it?
Old Oct 4, 2006 | 11:42 PM
blackend's Avatar
blackend
nothing just make sure the kit for AT and if you want you can add AT oil cooler and main thing VB.good luck with your install
Old Oct 5, 2006 | 12:32 AM
taurran's Avatar
taurran
From my understanding, at stock power levels with the kit there should be no need for a valve body upgrade.
Old Oct 5, 2006 | 03:22 AM
blackend's Avatar
blackend
yes but for his AT safety
Old Oct 5, 2006 | 03:29 AM
jj350z's Avatar
jj350z
I had my supercharger for 400miles 367whp 335tq and the tranny blew. I had to buy a brand new transmission and right now my cars at carv2 getting the SGPracing Valve body. Dont even do it until you have the money to get the vb. Also you need a tranny cooler.
Old Oct 5, 2006 | 05:23 AM
350z on DUBZ
So the stock tranny is really not strong enough to handle the turbo?
Old Oct 5, 2006 | 06:58 AM
617G's Avatar
617G
I've had my vortech for 2 weeks and have put 1,000 miles on it already. My tranny is fine. No issues other than the ones I had before f/i, which are minor and the dealer is looking into it because I mentioned to them I had it before and they're cool like that. Also, I have 47k miles on my car. You should flush your tranny and change your rear diff fluid before the install, though, if you haven't recently.
The only thing is, I'm not sure about a turbo. It's a hit or miss. Our tranny is very strong, but you never know, just like with the engine. Some people last thousands of miles, some dont make it off the dyno. It's a risk you have to be willing to take. Also 400 lb/ft when you shift with a turbo is going to put a lot more stress on the tranny.
Old Oct 5, 2006 | 07:29 AM
doug's Avatar
doug
didn't i just see this thread last week?
Old Oct 5, 2006 | 07:31 AM
350z on DUBZ
So with the st kit and exhaust and 5/16 spacer where should be at far as hp?
Old Oct 5, 2006 | 08:06 AM
617G's Avatar
617G
^^Use the search button for that. I've seen anywhere from 350whp to 400whp
Old Oct 5, 2006 | 08:15 AM
350z on DUBZ
That's nice...... I think I'm going to buy the kit sometime this month.
Old Oct 5, 2006 | 08:57 AM
doug's Avatar
doug
I suggest you do a lot more research and use the search function and then buy the kit in 2 months.
post a thread and getting a couple answers is not enough to go FI.. research research research
Old Oct 5, 2006 | 09:08 AM
350z on DUBZ
I understand what u saying but I do know I lot about cars and turbos I just wanted feed back about the kit.
Old Oct 5, 2006 | 09:18 AM
doug's Avatar
doug
its not knowledge of cars and turbo that are the issue.. its knowledge of the High compression VQ Engine and Turbo Kits that wern't mean't to be attached to it..
if you already have that knowledge.. then i say go forth
Old Oct 5, 2006 | 09:49 AM
350z on DUBZ
Oh I will...I'm not one of them guys who wants 600hp so I know how far to go man.
Old Oct 5, 2006 | 10:11 AM
doug's Avatar
doug
yeah but these motors blow anywhere from 300 whp to 600 whp
Old Oct 5, 2006 | 10:26 AM
617G's Avatar
617G
^^ +1...It's hit or miss...be ready for a miss
Old Oct 6, 2006 | 10:21 AM
ZLadie2000's Avatar
ZLadie2000
wow with all these negative comments about turbo, def. makes me want to go Nitrous because my Z is my only car...
Old Oct 6, 2006 | 10:34 AM
doug's Avatar
doug
Nitrous is worse.. its INSTANT power.. unless you get a progressive controller... HP is HP .. TQ is TQ .. weak engine is a weak engine.. you are going to blow your engine on the same HP and TQ if your engine is weak if you have an SC, Turbo or Nitrous..
and don't give me the.. i am not running Nitrous most of the time and i only use it when i race.. same goes for a turbo...
Old Oct 6, 2006 | 03:59 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I dont think nitrous is worse. In the 3+ years Ive been on this site, Ive never read of anybody blowing a motor on nitrous-up to 150 shot. Only"person" to do it was Performance Nissan and Andrew Rubio driving back in the day testing the limits-before the PE TT kit went on that car. N20 is so much easier IMO, and because it cools the intake charge so much, the timing doesnt have to be dead on like on a turbo car (150shot retard is only 3 or 4 degrees compared to 10-12 degrees retarded for a turbo set-up @ redline)many guys just run race gas with stock timing and have no issues and make great power. In the past few months we have had 3 or 4 guys run from 11.8-12.3 @ 115-119mph on stock blocks and decent set-ups. Stock block TT owners look out
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
