My EGT is ticking..
When I start the car my EGT needle cycles to the end and goes back to start but then the needle tickes between 525 and 550 well somewhere around there...
Anyone know what would cause this? its a DEFI EGT..
Hmmm I just took my car apart and put a ATS carbon-carbon in so I guess a leak is possible although if I have a leak its a small one....The EGT will tick even if the car is not running just powered on..but since the EGT cycles on start-up I would think its not messed up wiring.
I've got a similar problem with my Autometer Nexus EGT gauge but without the clicking sound. When I start the car, the needle cycles from 392F to 1200F continually until the car warms up. The gauge worked perfectly for about a month and then the cycling problem started. I haven't figured out the problem yet.
Have u checked the wiring from the probe to the gauge? u know to c if there is any damage.
Oh and its not making noise just moving like a ticking clock
A while back, the two wires in the back that attach into pins in the main clip pulled out, i tried every combination of putting the wires back in, to get the gauge functioning...a dew combinations made the gauge tick...and pretty much do exactly what you are describing..i figured out the correct wiring and it hasnt happened since
good luck
TODD
Does your EGT still read correctly? Mine still works and stops cycling once EGT gets over 900F which is weird.
my EGT works I think it just cycles and does not ready steady..Im gonna try to rewire it later and hope it fixes the cycle problems..I never drove enough to get the car hot too so well c...
InjectedPerformance
Dec 23, 2004 07:36 AM
12SecZ
Jul 10, 2004 03:16 AM
