Vortech Guru's...pls see if you can lend some advice!
Old Nov 3, 2006 | 05:37 AM
  #41
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by ForceInduction
With the Vortech Bypass Valve it should be closed if you pull it off. If you suck on the vacuum tube on top it will then open.
So if you are saying that you blew into it and it closed then this is your problem. Cause the bypass should be closed if nothing is hooked up to it.
If you don't feel its the bypass you might want to check your fuel pressure. If you are running to rich or lean it will cause you not to be able to build up boost.
we rigged up a "weapon of mass destruction" to detect a boost leak, plugged it in before the intercooler, tiny little leaks, nothing big, fixed those, manifold fine, still not making boost, gonna tighten the belt in a few hrs, if that doesnt work, then pull the intake manifold and inspect the lower plenum.
Thanks guys
TODD
Old Nov 3, 2006 | 09:33 AM
  #42
sentry65's Avatar
sentry65
the burninator
could the blower just flat out be bad? Maybe something inside of it is loose and the blade just loosely spinning with no real force
seems like if that blower was working fine, there'd be lots of boost
would a leak be enough to let 8 lbs of pressure completely slip through - and especailly not make some piercing loud whistling sound? Otherwise it'd have to be large leak I'd think
Old Nov 3, 2006 | 09:43 AM
  #43
617G's Avatar
617G
When I had a leak, every time I let off the gas during high revs, it would make a piercing whistle sound like sentry said, and it was a small leak. The clamp on the intake manifold pipe wasn't tight enough. How could you possibly be leaking 8 lbs of boost and not hear it? Doesn't sound right...
Old Nov 3, 2006 | 11:46 AM
  #44
Barzten1's Avatar
Barzten1
The blower is being sent back to Vortech for a look.
Old Nov 3, 2006 | 12:05 PM
  #45
booger's Avatar
booger
Thanks guys
TODD
LOL...I have a name for my little rig . I hope you meant you hooked it up before the BOV and not before the IC ???? You didnt test the BOV for leaks under boost conditions if it was after the bov .
Todd
Even if it was the lower plenum that was leaking . Wouldnt you think you could hear it leaking ???
Old Nov 3, 2006 | 03:10 PM
  #46
350zDCalb's Avatar
350zDCalb
builtZmotors
Todd
I completely blocked off the BOV, removing it from the equation, to no avail! BOV does not affect the scenario...we hooked up the "weapon" before the intercooler, because it fit easier...this was after the BOV was ruled out..
blower is out, boxed up and in transit back to Vortech!
Thanks guys for all the effort
-TODD
Old Nov 13, 2006 | 10:55 AM
  #47
jpc350z's Avatar
jpc350z
Any update on this thread??
Old Nov 13, 2006 | 11:01 AM
  #48
sentry65's Avatar
sentry65
the burninator
i had a boost line hose come undone once and couldn't hear it
Old Nov 13, 2006 | 02:01 PM
  #49
Barzten1's Avatar
Barzten1
Sent the blower back to Vortech to get inspected. Still waiting on a response from them.
Old Nov 13, 2006 | 06:27 PM
  #50
kevinapex's Avatar
kevinapex
thoes wheels turn s l o w!
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
Calinismo350z
Sep 14, 2015 04:04 PM
