Going stage 3 from stage 2 stillen..?'s
Old Nov 2, 2006 | 11:44 PM
BlackSpec02's Avatar
BlackSpec02
Default Going stage 3 from stage 2 stillen..?'s
Hey I am going from stage 2 to stage 3. I have the pulley in hand, is there anything else I should do? Like new belts or different sized belts or reset the ECU by disconnecting the battery...??? Or do I just swap pulleys and drive?
Thanks!
Old Nov 3, 2006 | 12:02 AM
WA2GOOD's Avatar
WA2GOOD
Thanks!
Change pulley, inspect all the belts, re-tighten/check for tension, and you are done, thats it, enjoy and be carefull. Be sure that you DO have the (at least) 1 step colder spark plugs in the car and at least (GOOD) 91 oct. fuel at all times. Be carefull and enjoy!!!!
Old Nov 3, 2006 | 12:16 PM
BlackSpec02
I have whatever plugs have been in the car since the stillen unit was installed as stage 2 by mossy nissan.... any idea if they changed them or if they are stock and I should purchase new ones?
Any recommended plugs? NGK?
Old Nov 3, 2006 | 01:51 PM
superchargedg's Avatar
superchargedg
Damn Noobs
if mossy did it they would have changed the plugs to one step colder.
Old Nov 6, 2006 | 12:39 AM
BlackSpec02
Thanks for the info!
Did the plugs come with the kit? I never actually had the kit in hand or anything before it was on the car.
Old Nov 6, 2006 | 12:43 AM
WA2GOOD's Avatar
WA2GOOD
No, the plugs did not come with the kit, but the directions indicate to change to 1 heat range lower. Like superchargedg said, Mossy should have and probably did change them. Check the invoice......
Old Nov 6, 2006 | 12:59 AM
BlackSpec02
Okay, thanks!
Old Nov 6, 2006 | 10:08 PM
Triple8Sol's Avatar
Triple8Sol
Why not just go straight to Stage 4? That's my plan by springtime...
Old Nov 7, 2006 | 12:25 PM
BlackSpec02
Because I got a stage 3 pulley for about 60 bucks and stage 4 is about $800.
EnjukuRacing
Sep 30, 2015 06:55 AM
foxsmp26
Sep 25, 2015 09:48 AM
