CFM Calculations
Old Nov 7, 2006 | 07:27 PM
  #41
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by JETPILOT
HEY !!! Will the GT-K bolt up to the piping installed now?
JET
There is A GT-K that should yes. The GT-K 550 should.
Old Nov 7, 2006 | 07:44 PM
  #42
MIAPLAYA's Avatar
MIAPLAYA
GT-K email attached\..
Attached Thumbnails CFM Calculations-gtkemail.jpg   CFM Calculations-gtkemail2.jpg
Old Nov 7, 2006 | 07:46 PM
  #43
JETPILOT's Avatar
JETPILOT
Do you think that the GT-K 550 will fit my needs and get the job done? 500whp? If you say yes.... then I will wait for it's release!!! Please say yes!!!
JET
Old Nov 7, 2006 | 07:51 PM
  #44
MIAPLAYA's Avatar
MIAPLAYA
JET
I personally think so but I would like to see what the Turbonetics engineers use as well. They have been matching turbos to motors for a LOT longer then any of us here... The GT-K 550 is rated to 600 so I would say it would probably fit your needs.
Old Nov 7, 2006 | 07:52 PM
  #45
JETPILOT's Avatar
JETPILOT
600 BHP.... Not WHP! Correct?
JET
Old Nov 7, 2006 | 07:53 PM
  #46
MIAPLAYA's Avatar
MIAPLAYA
JET
600 HP worth of air yes. So crank...That would make it 510 WHP..
Old Nov 8, 2006 | 12:23 AM
  #47
JETPILOT's Avatar
JETPILOT
Which GT-K is that VQ powered 240 running? Are there any power numbers for that car?
JET
Old Nov 8, 2006 | 03:56 AM
  #48
aalzuhair's Avatar
aalzuhair
Originally Posted by MIAPLAYA
You should be looking at CFM for the entire operating range not just peak pressure. That formula is correct for CFM just make sure to convert to lb/min as most compressor charts read in lb/min. What you are basically looking for is the peak air flow you require the turbo to produce (although its a VERY rough estimate each 1 lb/min of compressor air flow can be translated to 10 WHP). Using a rough calculation (see prior note) if you want to make 450 RWHP you want to look at what efficiency the compressor is for 45 lb/min at the pressure ratio you plan to run. Not to talk **** at all but have you read the book Maximum Boost by Corkey Bell? It would help you better understand what to look for in a turbo (compressor and turbine that is).
I agree.
Jet, the attached excel sheet might be of help to you. It will give you 6 points of CFM requirements
Az
File Type: zip
Old Nov 8, 2006 | 09:57 AM
  #49
MIAPLAYA's Avatar
MIAPLAYA
JET
I believe it has a GT-K 550 on it. There are no final numbers on it yet. Its final tune hasn't been done yet...
Old Nov 8, 2006 | 12:17 PM
  #50
QuadCam's Avatar
QuadCam
Rob,
do you still think you will have Stage 2 info this week? I am so anxious even though I know nothing will ship until January.
Old Nov 8, 2006 | 02:25 PM
  #51
redline350ZZ's Avatar
redline350ZZ
My brother went to SEMA and he was told the GT-K turbo's are underated..by who I dont know but someone at the stand..
Old Nov 8, 2006 | 02:42 PM
  #52
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by QuadCam
Rob,
i'm still hoping to yes. I can only post the info I get though...
Old Nov 8, 2006 | 02:46 PM
  #53
MIAPLAYA's Avatar
MIAPLAYA
Not sure... I will say they are going to flow plenty for the pressure they are being run at
TrboMike
North East
Sep 28, 2015 06:36 PM
Chebosto
Aug 6, 2003 06:31 AM
NiceGuy
Jan 13, 2003 10:26 AM
