Which Hood and Bumper is Best for FI Track Z?
Old Dec 19, 2006 | 01:49 AM
DRE350's Avatar
DRE350
Default Which Hood and Bumper is Best for FI Track Z?
I am looking for a hood and bumper that
1. maximises the airflow to intercooler/radiator/coolers
2. has the best ability to dissipate heat
Thanks
Old Dec 19, 2006 | 04:20 AM
Eagle1's Avatar
Eagle1
The VIS carbon fiber hood for the 350Z and G35 is a very effective one for expressing heat. Note the addition of the scoop on the nose at the high pressure area, to help create a flow that sucks air out of the six "gills". The exhaust slits are angled towards the A pillars, rather than straight back onto the windscreen, which I also think is an advantage over many other designs. Mine is painted OEM white in this picture below.
Old Dec 19, 2006 | 06:10 AM
Eagle1's Avatar
Eagle1
For the bumper you will have to look around as there are many choices. Aesthetics as well as functionality are a concern. You may want to look into the aero characteristics at this time, if you are buying a new bumper, and something with some downforce is probably a good idea, as long as you look into some rear underbody diffuser to pull it down in the rear.....or....a WING!
Obviously, if you have a track car with FI you will have four primary competitors for air flow. The radiator, the intercooler, the oil cooler, and the power steering cooler. However, you should also consider two intake ports dedicated to ducting air to the calipers on each of your front brakes. (It gets real crowded up there!)
Good luck.
Old Dec 19, 2006 | 06:13 AM
chimmike's Avatar
chimmike
the biggest thing you want to do is make sure the air can escape. You can let in as much as you want, but if it doesn't have a smooth, quick escape route, you're just going to pile up hot air in there.
it's a bit more complicated than just a vented hood
Old Dec 19, 2006 | 08:39 AM
Chebosto's Avatar
Chebosto
Cwest or Ings hoods are very good venting.. also the veilside with the three vents.
front bumper i'd suggest the doluck, top secret, vertex.. all have wide three openings perfect for placement of oil coolers and intercoolers.
Old Dec 19, 2006 | 09:35 AM
priscilla ls1's Avatar
priscilla ls1
Try going with some better air disspension fenders to let the hot air out.
Old Dec 19, 2006 | 11:23 AM
WA2GOOD's Avatar
WA2GOOD
Hahaha. I thought about this idea, but then when you really look at the car you will see there is no coalition between the front bumper/ hood air inlets and the fenders. They are separated and blocked off by the inner fenders.
Old Dec 19, 2006 | 11:33 AM
chimmike's Avatar
chimmike
+1....someone needs to look in his engine bay more lol.
the key would be to get the air our the back of the engine bay faster, via rear hood spacers or a better airflow directive out the back of the engine bay.
Old Dec 20, 2006 | 02:44 AM
DRE350's Avatar
DRE350
Thanks for the input guys. I'll look into all the suggestions. Who sells hood rear spacers?
Old Dec 20, 2006 | 05:26 AM
buzzardmountain's Avatar
buzzardmountain
If that's the case, then Do-Luck Lift-up hood FTW!
However, No-Luck-USA FTL!!!
Old Dec 20, 2006 | 05:48 AM
gringott's Avatar
gringott
I have to agree, the No-Luck hood seems like an excellent design promote airflow through the engine compartment. But then again, WTF do I know?
BTW, yesterday we were sitting in Sonic Drive in, engine off, watching the heat waves coming from the vents on the Seibon VT hood. At least at rest, it really lets the heat out.
Old Dec 20, 2006 | 05:59 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
If price isn't an issue, I'd say Do-Luck. Otherwise Seibon VT FTW !
Old Dec 20, 2006 | 09:20 AM
Eagle1's Avatar
Eagle1
Just a few washers will do the trick, there is no custom part for the job necessary.
Old Dec 20, 2006 | 09:27 AM
Lo$t's Avatar
Lo$t
+1.. i can see the vapors coming out. it Appears to be releasing a lot of heat. also i know thats its pushing a good bit of air when moving as well because i spilled a little bit of oil on a hot pipe when changing a line. after heating up it was releasing a little bit of smoke. i could see the smoke coming up out of the hood. anywho.. just my .02
Old Dec 20, 2006 | 09:41 AM
Chebosto's Avatar
Chebosto
or... goto your reputable body shop, have them cut three holes, two rectangles in the front, one long and thin over the plenum, and have them bend the leading edge of each of the hole upwards at a slight angle, then you'd have your own vented hood. probably lighter than 80% of all the 'carbon' hoods out there and you'd only be down like $300 for labor and some touch up paint.
Old Feb 20, 2007 | 12:36 AM
DRE350's Avatar
DRE350
For the hood, I've decided to either cut the stock one (like Chebosto suggested) or buy one similar to Eagle 1's hood.
Now I'm still deciding on the front bumper. I figured since I'm changing it anyway, I should look for one that has some downforce. Besides Kognition, are there any others?
Justin100
Nov 25, 2021 06:26 AM
apex locator
Jul 23, 2021 02:27 AM
