Check Engine Light With F-con
Old Dec 26, 2006 | 09:37 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Originally Posted by phunk
Does this also keep the code from being stored in the ECU so that people can pass emissions diagnostic tests?
Absolutely ,even the flash will not be detectable and steel can communicate with factory Ecu via obd2 and pass all the readiness tests ,it works like a charm
Old Dec 26, 2006 | 11:13 AM
meatbag's Avatar
meatbag
Sounds like that is the best answer then. Hopefully it there will be a 350z/g35 application soon.
Old Dec 26, 2006 | 12:42 PM
Philthy's Avatar
Philthy
Boost Junkie
Only down side is the price - +$600 to turn off the check engine light (if you already have an engine management system)... Also, once you mate the COBB system with an ECU, it can not be used with any other ECU unless it's unmated... And ofcourse, once it's unmated, the ECU returns to stock...
Old Dec 26, 2006 | 01:39 PM
meatbag's Avatar
meatbag
Maybe they can work out something for just disabling the CEL. Ill take my tape over $600 lol.
Old Dec 26, 2006 | 01:48 PM
mrtomcat's Avatar
mrtomcat
$600 is pretty steep but in all honesty I'd spend it, I hate that cel especially since I'm cell hell right now between the regular cel code and the brake/abs/tcs/slip light being on since that issue still hasn't been resolved. My dash board looks like a xmas tree and I'm too broke right now to get that all fixed.
anyway, back to subject...once this flash is being released for the z I want one
Old Dec 26, 2006 | 02:52 PM
phunk's Avatar
phunk
CJ Motorsports
i wonder if its anything technosquare could do if they tried?
Old Dec 26, 2006 | 03:17 PM
mrtomcat's Avatar
mrtomcat
doesn't the fcon reset everything the technosquare flash does? I used to have the flash and that's all gone now (raised limiter for example...)
Old Dec 26, 2006 | 04:08 PM
phunk's Avatar
phunk
CJ Motorsports
no, the fcon controls the fuel injection and ignition systems - so whatever tuning you had done to the stock ECU is still in there, it is just going to waste because the stock ECU isnt in control of those components anymore. If I were you, I would swap your ECU to someone for their stock one and $$$ just to get some money back.
Old Dec 26, 2006 | 04:28 PM
mrtomcat's Avatar
mrtomcat
thanks for the info. I just had the limiter raised so it isn't the full tune one
Old Dec 26, 2006 | 05:54 PM
Gman2004's Avatar
Gman2004
If you have already have the full flash Technosquare will only charge $150 for an additional flash. I'd be interested since I have the full flash already.
Old Jan 18, 2007 | 07:18 PM
ML2000's Avatar
ML2000
I would pay more just to get my CEL off, has anyone heard of any new products that will do this?
Old Jan 18, 2007 | 08:18 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
We did find a solution to this issue ,it a combination of flashing the Ecu and certain configurable options on the f con ,it is being tested in our shop car to confirm the fix .we will be posting a complete write up on our shop car in the next few days, stay tuned .
Old Jan 19, 2007 | 05:07 AM
ML2000's Avatar
ML2000
Thanks for the info Sam, please keep me updated.
Matt
Old Jan 19, 2007 | 08:45 AM
ma_sha1's Avatar
ma_sha1
Default -
Anyone tried the pocket scan tool? $50
It should remove the cel but you'll have to do it at each start.
I was going to get this but after my S/C, there's not being any cel yet.
http://www.amazon.com/Actron-CP9125-...8&s=automotive
Old Mar 2, 2007 | 12:57 PM
BrianLG35C's Avatar
BrianLG35C
Did this work Sam?
Old Mar 2, 2007 | 01:07 PM
roncfpz's Avatar
roncfpz
Originally Posted by BrianLG35C
Did this work Sam?
+1.......I'd like to know too. I hate getting that damn light on all the time. I consistently get the 1168 and 1274 codes. For the money spent on an Fcon Vpro it would nice not to get SES lights ALL the time.
Old Mar 2, 2007 | 02:05 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Did this work Sam?
absoluuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuutely
No more check engine light on all our f cons
Old Mar 2, 2007 | 03:39 PM
  #38
BrianLG35C's Avatar
BrianLG35C
Can you share how you accomplished it?
Old Mar 3, 2007 | 02:11 PM
  #39
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
This did not just happen over night I believe I've spent over 40 hours chasing this issue. a lot of it is really to utilize what the F Con as engine management can do. If you can make the ECU stay in open loop mode, the ECU will never self check it self and set any codes.
So to answer your questions. A combination of tunning and flashing the ECU (GTM Spec Flash). Something to share, we have some cars getting tested at a referee smog station and the car DID pass the smog inspection on the F Con.
This is by no means an easy task and is VERY time consuming, So I can see why most tuners would not do it.
sam
Old Mar 3, 2007 | 06:44 PM
  #40
accordfreak's Avatar
accordfreak
so the cobb turns the cel off completely for all codes? If so, what if there's a real problem that comes up? Would it be possible to just turn off that one code that goes off all the time instead of all of them?
