Aps Tt Built Motor Unichip Map
Old Jan 12, 2007 | 05:45 AM
gecof1's Avatar
gecof1
Newbie
Default Aps Tt Built Motor Unichip Map
Dear all,
I am in the process of build my motor. I have purchased the Arias Pistons 9.5:1 and Pauter rods. I want to know if any of you can send me a Unichip map compatible with my new setup in order not to start from scratch. In addition does anyone have any idea if the base setup, before built, is safe as far as running in period is concerned?
I would appreciate your help once more since here nobody has the know how to properly tune the car. Fine tuning is possible by the local dealer of Unichip, but the base map would be of great help.
Old Jan 12, 2007 | 08:24 AM
Zivman's Avatar
Zivman
Originally Posted by gecof1
Dear all,
Dropping the compression will require larger injectors than the out of box kit included. As a result, you will need the unichip Q, utec, or an Fcon to control them. With the out of box injectors, your tuner shouldn't have much of a problem tuning your car. Too make decent power and make the build worthwhile, larger injectors and a new EMS will be needed
Old Jan 12, 2007 | 08:31 AM
Enron Exec's Avatar
Enron Exec
Dear all,
I built my motor with 8.6:1 pistons on a new APS TT kit. I broke the car in on the base map from APS on 93 oct fuel. I had no problems with that because a/f and timming where all within safe perameters with the built motor on the stock Unichip tune. After ~2000 miles, i had the Unichip tuned for 11 psi.
Old Jan 12, 2007 | 08:46 AM
BrianLG35C's Avatar
BrianLG35C
You got the older Unichip up to 11psi? What injectors are you running?
Old Jan 12, 2007 | 10:53 PM
gecof1's Avatar
gecof1
Newbie
I also have the UTEC, but the problem is who is going to tune it. I don't want to mess around with the car. As far as injectors is concerned according to my local Unichip dealer, Unichip does not have any problem of driving larger injectors. According to APS each of the injector is good for 100PS/Cylinder, based ofcourse on the stock compression ratio. Do you suggest the 600CC injectors?
Old Jan 13, 2007 | 04:12 AM
Zivman's Avatar
Zivman
I would recommend getting the APS big fuel system and using the Utec, or upgrading to an Fcon EMS.
11 lbs could be doable on the out of box APS injectors and classic unichip. I ran 14 lbs peak, down to around 10 at redline with those components
Old Jan 13, 2007 | 10:09 AM
clemlover15's Avatar
clemlover15
I just read that in a post that UTEC does not work with the injectors of on the APS Extreme fuel kit,
Old Jan 14, 2007 | 04:36 AM
Zivman's Avatar
Zivman
Don't even see how that would be possible for it not to work
2ndchanceZ
Oct 26, 2015 08:03 PM
