PE TT Question. Actuator springs
Old Feb 4, 2007 | 07:07 PM
priscilla ls1's Avatar
priscilla ls1
Finaly finished and what a ride(PITMFA) this has been the actuator on the drivers side is not possible to take off while the engine is in so after I cut the spring out with a dremel I had to kind of rotate the stiffer spring in. I put everything back on and went for a little ride I tryed not to get on it to much because I know I will overboost But I did hit 17psi for a split second and then I stopped I'm going to wait for the retune. But I know the springs are holding up well under boost. I put in some nice fog light and PE's rediator hoses while I was in there. Retune coming up 22nd.
Old Feb 5, 2007 | 02:50 AM
Revsport's Avatar
Revsport
Nice one. Keep us posted on how it goes with the re tune
Old Feb 8, 2007 | 05:25 AM
CESAROTORRES's Avatar
CESAROTORRES
Default Water Cooled TT
Does the twin turbos on the PE kit are water cooled? (Like the one on the APS kit)
Thank you,
Cesar
PS.
I am having a hard time trying to decided wich one to buy (APS or PE TT)
Old Feb 8, 2007 | 06:04 AM
Philthy's Avatar
Philthy
Boost Junkie
Thank you,
Cesar
PS.
Unless a change was made, the turbos support watering cooling, but PE doesn't provide the water lilnes in there kit...
Old Feb 8, 2007 | 03:36 PM
priscilla ls1
Yeah they are.
Old Feb 8, 2007 | 03:42 PM
CESAROTORRES
Originally Posted by priscilla ls1
Yeah they are, lines go strait to the pan.
Thank you everyone!
Cesar
Mattg350z
Oct 2, 2015 06:51 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
