vortec supercharge leaking...
Old Jan 27, 2007 | 12:22 AM
CraZ33Y's Avatar
CraZ33Y
Default vortec supercharge leaking...
hi all
my freind have his 2005 Z and he just go for FI by vortec supercharge + headers + Exhaust sys ...
and his supercharge keep leaking oil
he changed it three times since last month
but every time its leak againe ...
he can't drive his Z like 5 days without this problem...
I think it because he didn't have any mannagment unit ..... Am I Right
please some help..
Old Jan 27, 2007 | 02:37 AM
Barzten1's Avatar
Barzten1
Mine leaks oil too. Just had it sent back to Vortech to see if its in good order. When I put it back on it still leaks.
Old Jan 27, 2007 | 03:29 AM
CraZ33Y's Avatar
CraZ33Y
thats mean its from the super itself...!!
Old Jan 27, 2007 | 04:45 AM
booger's Avatar
booger
Where are these SC's leaking at? Barzten ? Crazy ?
Old Jan 27, 2007 | 05:48 AM
CraZ33Y's Avatar
CraZ33Y
from inside the super fan...
Old Jan 27, 2007 | 05:50 AM
booger's Avatar
booger
Is there oil in you intercooler pipes ? If so....the seal in the Supercharger is bad .
Old Jan 27, 2007 | 10:11 AM
Barzten1's Avatar
Barzten1
Mine leaks oil from somewhere under the blower. Can't exactly tell where but next week sometime I want to take it out again and check it out.
Old Jan 27, 2007 | 10:48 AM
CraZ33Y's Avatar
CraZ33Y
ill tell my freind also to check his SC.
Old Jan 27, 2007 | 10:52 AM
THE TECH's Avatar
THE TECH
What about checking your oil feed or return lines??? Maybe they just aren't clamped tight.
Old Jan 27, 2007 | 11:18 AM
eltness350's Avatar
eltness350
The Untouchable
i had that problem with the procharger...it could be the bolts that hold the plate to the motor that the blower attaches to. i didnt use silicone on some of them because i thought they were blind bolts...they actually went deeper into the motor then originalluy thought... mine was a simple fix..i hope yours is too ...good luck...
Old Jan 27, 2007 | 11:21 AM
booger's Avatar
booger
Most likely the clamp on the return line isnt tight
Old Jan 27, 2007 | 01:58 PM
THE TECH's Avatar
THE TECH
I think there's an echo in here.
Old Jan 27, 2007 | 02:30 PM
fklentz's Avatar
fklentz
I think that all Vortech units sent to the U.A.E are the models that leak because you guys have plenty of oil anyway. What's a gallon of gas cost there now?
Old Jan 29, 2007 | 06:02 AM
jpc350z's Avatar
jpc350z
Need to verify where the leak is coming from. I have a leak and believe its coming from the valve cover drivers side..Can be confusing to identify as coming from the blower. Replaced the gasket 2x and still leaks some..
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
