MI Forced Induction Thread... Turbonetics
Old Apr 24, 2007 | 07:00 AM
  #41
Kenk2's Avatar
Kenk2
Professional
Originally Posted by MI 35th
Alright time to bump my FI thread back up top, since i will be starting the install as soon as the parts arive.
A buddy of mine hooked me up with a charge pipe, and all new clamps and black silicon connections have been ordered.
With the UTEC installed and running great, I need to add a map sensor to it and I will have all the nessesary parts to do this project.
Any pre-game warnings about self install.
I am very worried about the a/c lines even though I have faith in my abilites.
Just take your time bro and you should be fine...
You can simply just move the Compressor out of the way and/also move the lines so they aren't in the way..
If you need a MAP Sensor, I have an extra one..
K
Old Apr 24, 2007 | 07:31 AM
  #42
push's Avatar
push
What happened to the full motor build and bigger turbo don? ;-)
Old Apr 24, 2007 | 01:13 PM
  #43
MI 35th's Avatar
MI 35th
OGPremierMafia
GRM happened push, I am bulding a RB motor for that hatch and have other priorities.
I still want a quick Z but the most ill do is prolly pistons and rods with some mild s7 camshafts. But until then it is low boost for me.
Old Apr 24, 2007 | 01:15 PM
  #44
MI 35th's Avatar
MI 35th
OGPremierMafia
K
I PMd you about the map sensor,
Thanks bud. I will be hitting this place up so much for info as the project gets underway.
Old Jun 11, 2007 | 06:41 AM
  #45
MI 35th's Avatar
MI 35th
OGPremierMafia
Update
June 11, 2007
If you look at the beginning date of this thread to now you can see I have been lazy about installing my turbo kit. Any way.
Comment on why its taken so long. I have finished another "Fun" quarter of school, Only 2 more and Ill have my 2nd degree with this one being Business Marketing. Also Has been interviewing with several regional airlines. As a CFI ive been busy building hour to continue flying.
Just Purchased Jet's Wastegate Setup Turbo Smart 48mm Wg dumped to Atmosphere.
Also Just installed Kenk's Map Sensor
I am missing Fuel Return & larger Injectors 440cc to trade for 650cc
I may just keep it at 7psi and 440cc returnless on my own tune until it makes its trip down to a shop. But I have yet to decide when to install.
I need a Wideband Controller and some gauges...
Thinking Fuel Pressure, EGT, Boost... Since I have stock oil pres, Volt.
Craig If you read this, I would definately buy one of those super AC lines you made from ya if you make more.
This week I am going to install the Fuel Pump and modify the regulator. (Phunk I will be PMing You)
