Highest APS TT Dyno #'s
Old Mar 16, 2007 | 10:14 AM
  #81
Julian@MRC's Avatar
Julian@MRC
Originally Posted by JRoC
What kind of other modiications are we talking about here?
There would be some clearance issues with the motor mounts, some piping modifications needed, and possibly some steerig shaft issues..Most of which will be easily resolved, but far easier than replacing both manifolds and adding external wastegates to a kit that is already on the car. Trust me, we toyed with the Idea of a log style manifold fabbed up to work with external WG's, but we quicky abandoned it as a cost effective feasable solution. we sent the mock up manifold we had to a shop in Chicago and let them have a go at it.
Old Mar 16, 2007 | 10:18 AM
  #82
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by buzzardmountain
Seeing BriGuyMax's location, I'm guessing GRD.....I could be totally wrong however.
I'd love to know as well......
Wrongo
Old Mar 16, 2007 | 10:19 AM
  #83
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Ah yes..the cracked manifolds that SP has right now...
Old Mar 16, 2007 | 10:28 AM
  #84
Julian@MRC's Avatar
Julian@MRC
Exactly...We had a set of cracked ones, we sent them to play with..
Old Mar 16, 2007 | 10:45 AM
  #85
KempieZ's Avatar
KempieZ
I have the turbos from the standard aps kit, but the exhaust manifolds for the extreme one. So I can easily install the external WG. What to do with the internal ones then?
Old Mar 16, 2007 | 10:48 AM
  #86
Julian@MRC's Avatar
Julian@MRC
Weld them shut...
Old Mar 16, 2007 | 11:10 AM
  #87
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
Funny, because I have a standard APS kit and considered the extreme for about .2 seconds before I realized I didn't want their fuel system, and huge overkill intercooler for my 600ish whp street car. I haven't spent a cent on my "external gate" setup for my standard kit yet. I pulled the motor myself and gave the manifolds to a friend that does fab work and he's working up manifolds as we speak which will not cost me anywhere near $700....all I need to do is buy the wastegates and compensate him for his time....total cost should be under $700, and I'll have a lot more flexibility with my boost control than the internal gate APS guys.
Unless everything is mocked up with the motor in the chasis you could end up with manifolds that dont fit correctly or wastegates that interfere with the bellhousing, hard waterline, etc......The labor is where quite a bit of the cost comes into play. Since you did it yourself, you saved $$$$$$.Actual cost for materials for the log manifolds should be around $400 if you use stainless weld L's,stainless head flanges and stainless WG flanges.The labor to build the jigs and assemble the headers is going to vary but if I was to do it, it would be in the $1000 range.It takes alot of time to get it right the first time.The jigs have to be strong to prevent the headers from warping,notching the schedule 40 304SS pipe is a real mother.I think MRCs rough estimate is on par with a typical fabrication shop. Sound like you are getting a heck of a deal
Funny you said huge overkill intercooler...........From our experience in dealing with 5" cores.They are no more effective then a 3.5 or 4" car unless you are going over 140mph. It takes that kind of velocity to push efficiently through a core that thick.
Old Mar 16, 2007 | 02:11 PM
  #88
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Exactly..and they block flow to the radiator...
Old Mar 16, 2007 | 02:14 PM
  #89
buzzardmountain's Avatar
buzzardmountain
Wrongo
Thanks for the input....
Old Mar 16, 2007 | 02:18 PM
  #90
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Don't worry, if it all works out...you'll find out soon enough.
Old Mar 19, 2007 | 04:02 PM
  #91
Nismo350ZRT's Avatar
Nismo350ZRT
Ok, since the shop gurus think the ewg conversion is not worthwhile, can you tell us what actuators are the best? Absolutely, without a doubt, 100% certain, answer would be great.
Old Mar 19, 2007 | 04:40 PM
  #92
Julian@MRC's Avatar
Julian@MRC
I would get a direct Garrett replacement actuator, rated for higher boost.
Old Mar 19, 2007 | 05:06 PM
  #93
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Forge actuator with the yellow spring. They have worked everytime we have used them. Just make sure you use a pre-TB pressure source when installing them, or you will tear the diaphram.
Old Mar 19, 2007 | 05:12 PM
  #94
Nismo350ZRT
Who sells them? Part #?
Old Mar 19, 2007 | 05:19 PM
  #95
Nismo350ZRT
I wasn't sure about the Forge actuator because I heard about the tearing but it sounds like you've figured out the problem. Thanks for the info Sharif.
Old Mar 19, 2007 | 05:23 PM
  #96
Sharif@Forged
Forged Performance
Wish I could take credit, but I just read the instructions included in the box.
Old Mar 19, 2007 | 05:33 PM
  #97
Nismo350ZRT
LOL. I guess the guys that had problems with them got the Japanese instructions. Seriously, though, your positive experience with them is what's most important.
Old Mar 20, 2007 | 01:53 PM
  #98
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
im using the forge actuators also.. and havnt had a problem yet.. i also have not tried to max them out.. so we will see
bcoffee20
Nov 19, 2015 06:39 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
foxsmp26
Sep 25, 2015 09:48 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
