rod/piston combo on ebay
Originally Posted by Sharif@Forged
No, it will not stroke the engine. Stroking an engine requires a shorter rod, a different pin location, a custom crank, and a host of other complex operations. Your stroke will be the same with Pauter or Eagle rods.
First off all, I want to thank you for your excellent service ¡ I’m in the process of installing my rods and pistons. My brother (Webcarconnection) tells me you are giving him a very good deal with the rods and pistons, please remember me when I make the order for the Utec and injectors!!!!
Could you explain to me what are (if any) the benefits of using over bore pistons? I can’t seem to figure it out yet. And do they increase the CC’s in the engine?
Thanks!
Originally Posted by Javi
Sharif:
Thanks!
Thanks!
I will take good care of you on the UTEC and injectors..no problem.The overbore pistons are just .020 overbore, or .5mm. This allows teh machinist to create the correct piston to wall clearance in each cylinder. Since each cylinder from the factory will be slightly different, this is a very important process. The minor overbore does not increase displacement by much....maybe 3.52L
lolwatbro
Oct 9, 2021 04:58 AM
