I Can Thank Turbonetics For This!!!
Old Feb 27, 2007 | 07:49 AM
Ten to Four Z's Avatar
Ten to Four Z
Thumbs down I Can Thank Turbonetics For This!!!
Over Boosted!!!!!!!!
Attached Thumbnails I Can Thank Turbonetics For This!!!-bent-and-normal-rod.jpg   I Can Thank Turbonetics For This!!!-bent-rod.jpg
Old Feb 27, 2007 | 07:51 AM
Julian@MRC's Avatar
Julian@MRC
Remember...BOOST does not kill engines..PEOPLE with BOOST kill engines..
Who installed it?
xyberai's Avatar
xyberai
Owch... Did they have the boost improperly turned up or did you turn it up? I believe i heard of an incident where a company installed TT and set the boost way too high and the same thing happened. Either way, that really sucks.
Old Feb 27, 2007 | 07:55 AM
Datona Jess's Avatar
Datona Jess
OUCH
That sucks hopefully the company that did it will help fix it at least...
Old Feb 27, 2007 | 07:56 AM
Ten to Four Z
I did and please don't question my install.
It was a cold night for south Florida (50's) and I have a 3 in exhuast with nothing but the muffler.
Old Feb 27, 2007 | 07:59 AM
Sean's Avatar
Sean
is the cylnder wall still in good shape?
Old Feb 27, 2007 | 08:00 AM
Julian@MRC's Avatar
Julian@MRC
#1)Did you have the Overboost pipe kit? (was it a newer kit?)
#2) did you add mods that increase boost pressure and reduce back pressure such as exhaust, plenum?
#3) What was you A/F like on the kit?
I have noticed the spring in WG in the TN kit does spike a bit, we usually replace them with the 5psi spring to prevent spiking..otherwise you see 9-11psi spikes alot..Even with the Overboost pipe.
Old Feb 27, 2007 | 08:02 AM
xyberai's Avatar
xyberai
Nvm
Ten to Four Z
Yes no damage.
03performz's Avatar
03performz
Sorry for the noob question, but are those our STOCK connecting rods?
I thought that's a no-no for turbo?
Old Feb 27, 2007 | 08:10 AM
Sean's Avatar
Sean
Yes no damage.
you got lucky, now you can go forged
Old Feb 27, 2007 | 08:29 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Very nice.. built motor time!
How much boost were you running?
Old Feb 27, 2007 | 08:44 AM
Ghost 350z's Avatar
Ghost 350z
Any more info on your setup or is that top secret ?
Old Feb 27, 2007 | 08:53 AM
Dubai's Avatar
Dubai
yeah need to know more info about your setup and who tuned it?!
Old Feb 27, 2007 | 08:59 AM
THE TECH's Avatar
THE TECH
Sorry to hear that bro. Let us know what route you decide to go on the motor.
Old Feb 27, 2007 | 09:04 AM
sentry65's Avatar
sentry65
the burninator
damn, sucks man hang in there! it'll get better. Stuff like this is always the worst feeling for the first few days, then you start to feel some hope in getting back on your feet
Old Feb 27, 2007 | 09:06 AM
TENGAI's Avatar
TENGAI
Be thankful that the block's intact... Could have been MUCH worse.
Old Feb 27, 2007 | 09:11 AM
Quamen's Avatar
Quamen
Agreed. Most are not so fortunate. When my rod let loose it punched a hole through the sleeve because the piston split in half and then it shot out the side of the block.
Old Feb 27, 2007 | 09:19 AM
sentry65's Avatar
sentry65
the burninator
some people with TT's have actually destroyed their actual turbos where the turbine wheels were all chewed up. At least the TN kit places the turbo up and out of the way and is further away from all the force blowing up in the engine
Old Feb 27, 2007 | 09:33 AM
MIAPLAYA's Avatar
MIAPLAYA
So how much did it overboost? Was the new piping installed? What was peak pressure measured? What was the AFR?
