HELP! Burned a cat
Well not really a "cat" but my catalytic converter from Turbonetics..... I heard this funny rattling sound from underneath the car and I shaked the pipes a bit and noticed that the rattling sound is from the cat like if its broken inside ... wth??
and I think I got a hole from the engine bay to my exhaust pipes cuz Its really loud and it smells like a whole lot of gasoline coming from that area...
do I have too much pressure on the pipes? too much heat?? heeeeeelllp
Get a straight through pipe and reweld one further down. Its either too hot or too cold or you're running too rich. Im betting you're running too rich and fuel is fouling up the cat.
Originally Posted by Zilvia
who needs a cat...................straight pipe time
I have the TopSpeed Pro exhaust system right now....and I'm not building up pressure like It should 0,65bar ...and I dont really here any air intake sound ...
end of march I'll be back in the valley *near turbonetics *
should I take my ECU along and check if everthing is ok?
Originally Posted by VashZ350
but how can I run too rich .. I had my ECU flashed and never changed anything .... ?
lots of things can affect the AF Mixture.. tempreture.. octane of gas.. damaged sensors.. lots of things can cause you to run rich
If I pedal to the metal..it goes down to 9,5 to 12ish.... and if I'm idle it jumps between 14 and 20...
it sounds high..but how can I change the mixture ? by UTEC only? or is there a other way...?
someone told me that I'm not getting enough air and I'm overheating
The law wants the cat and if not I wont get TUV on the car and its not street legal in germany.......
