Parts for UTEC
Old Mar 13, 2007 | 11:57 AM
Zilvia's Avatar
Zilvia
Default Parts for UTEC
What are the needed parts to run the UTEC ecu..........
im not looking to have multi boost maps or anything. Just need it installed for tuning.
Old Mar 13, 2007 | 12:10 PM
Zilvia's Avatar
Zilvia
bump
Old Mar 13, 2007 | 12:33 PM
QuadCam's Avatar
QuadCam
search is your friend.
if you want to self tune, I'd suggest the Tuner Wideband.
If you are going FI, get the MAP sensor.
If you want to control boost, get the BCS.
The map switch isn't necessary, but it is a cool cheap add on.
Old Mar 13, 2007 | 06:48 PM
Zilvia's Avatar
Zilvia
well you kinda help'd
so i do need the map sensor then............cool
thanx (read the rest next time)
Old Mar 13, 2007 | 07:04 PM
2slo2bfurious's Avatar
2slo2bfurious
lol, you must be bored...
Old Mar 13, 2007 | 07:28 PM
QuadCam's Avatar
QuadCam
I guess that means you are adding an SC or Turbo kit.
We can be more helpful if you give us more info.
Old Mar 14, 2007 | 01:51 AM
Zilvia's Avatar
Zilvia
Well if you have been around long enough you would know.................but i guess i need to update the world becuase i changed my siggy
PETT
Borla TD
going on a DD
just wanna make it as safe as possible
And i was wondering if there where any extra parts i had to buy in order to install the UTEC. Because i know with the HKS F-CONs you have to buy the $$$$ harness. And i read the descriptions on FP.com but i couldnt tell if i actullay needed any of the others.
Old Mar 14, 2007 | 04:41 AM
Gilley's Avatar
Gilley
You could also call TurboXS to see what you need. The UTEC uses the stock ECM wiring harness, no no extra harness is needed.
Old Mar 14, 2007 | 02:05 PM
Zilvia's Avatar
Zilvia
^^^ Yea thats pretty much what i was looking for, guess i should have stated that.
Thanks
Old Mar 15, 2007 | 05:13 AM
IIQuickSilverII's Avatar
IIQuickSilverII
you are not special man,....how on earth is everybody suppose to known what you are doing?
and yes SEARCH!. IT was very easy to look for the info, in under 10 minutes really.
Old Mar 15, 2007 | 05:56 AM
Zilvia's Avatar
Zilvia
it wasnt so much searching as it was me not saying what i was looking for in the beginning.
which was would i need a diff harness.
2ndchanceZ
Oct 26, 2015 08:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
_bit
Oct 2, 2015 07:49 AM
