JWT TT getting impatient
Old Apr 13, 2007 | 07:35 AM
THE TECH's Avatar
THE TECH
Originally Posted by mok5
The cats not heating up fast enough has always been an issue with not OEM TT cars. But the cat lighting up issue is for satisfying the requirements for getting the CARB EO #. Someone correct me if i am wrong, the JW TT kit should still pass the CA smog test??? Or is part of the smog test still testing to see whether the end results of the cats not lighting up fast enough?
No competent smog tech is gonna even put your car on the machine with a turbo setup and no CARB EO.
Old Apr 13, 2007 | 08:48 PM
mok5's Avatar
mok5
True statement, but you know and I know that not every smog tech here in LA is competent. If you have enough of that "green stuff", they'll put your car on the rack without any issues.
But the basis of my previous statement was based on whether the JW kit would pass the smog test or not? Even though it has no CARB EO...I guess time will tell when some of these cars need to be tested.
Old Apr 14, 2007 | 05:09 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
If I had one, I would bet that it would pass.
Old Apr 14, 2007 | 05:53 AM
mok5's Avatar
mok5
My guess would be that it would pass also.
Old Apr 14, 2007 | 07:06 AM
Gary Evans's Avatar
Gary Evans
It would pass a tail pipe test and a ECU scan. It is the cold start test that so far cannot be passed. The state testing agencies do not conduct a cold start test. The visual inspection is the problem and the consequence of failing is significant if you want to continue driving the car on the road. In Az as least if you even sell a non- compliant car w/o telling the buyer it can only be legally be driven off road you are liable. The regs have plenty of teeth if enforced. Most states use CARB standards as the gold standard so it isn't just a Cali issue.
If would appear from what has been approved thus far that the only FI capable of passing CARB is going to be a supercharger since they do not reduce exhaust gas temperature at the cat/s.
Old Apr 14, 2007 | 08:16 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
I wonder if thermal coating all the headers and exhaust tubing would help. It should keep the heat in, which the turbos would use some of, but also enough might be left over to help with the cold start.
By the way, no emissions in most of Colorado! (except Denver) which is why I bit the bullet and got my JWT TT kit. When the USMC moves me somewhere else in 2 years, I'm keeping my house here and renting it out. I can use that as a legal means of keeping my car registered in Colorado, thus avoiding the CARB *****.
Dave
Old Apr 14, 2007 | 10:11 AM
Hydrazine's Avatar
Hydrazine
Coatings were tried.
The turbine, housing and manifold simply has too much thermal mass and surface area for a cold start...
Old Apr 14, 2007 | 10:24 AM
Navygolf13's Avatar
Navygolf13
So, are you guys saying that you think it would pass a smog test if the tech didnt know what to look for? I think I understood that right. Makes sense, JWT just cant get the Carb sticker from Cali, but the test wouldnt know it was there....interesting!
Old Apr 14, 2007 | 03:29 PM
mok5's Avatar
mok5
Yes...that is exactly what I am guessing, that it will pass emissions, but no CARB EO sticker. I do recall seeing a JWT Popcharger EO sticker, and for a moment there I thought it was for the TT kit. Not sure the tech guy will know the difference or not. I do know that some of the tuners can tune the Vcon IS (FMU) and make a TT pass emissions. I think some of the tuners are clever enough to tune the car within specs to pass emissions. I guess we will have to wait a few more years for the 03's to start getting smogged.
Old Apr 14, 2007 | 03:38 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Oh well. I htought I had a good idea
B Esquire
Sep 24, 2015 07:52 AM
