wideband
Old Apr 11, 2007 | 10:01 PM
Cannysage's Avatar
Cannysage
Question wideband
how important is it to have both banks? I have one gauge sitting in the middle of nav - not so attractive looking..
Old Apr 12, 2007 | 05:42 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Just from preliminary testing, we have observed some noticeable differences between the two banks. Nothing cylinder trims doesn't clean up though. I suppose having a wideband in each cylinder would be ideal, but the temps pre-turbo are too hot... 6 EGTs? In a normal street setup this would be overkill if you weren't looking for every last HP considering you could just add a buffer of safety by running it a hair on the rich side.
Old Apr 12, 2007 | 05:43 AM
THE TECH's Avatar
THE TECH
I'm using dual channels. I wouldn't suggest otherwise.
Old Apr 12, 2007 | 06:59 AM
twenzel's Avatar
twenzel
Does the UTEC Tuner Pro support the use of dual wideband o2?
Old Apr 12, 2007 | 07:01 AM
THE TECH's Avatar
THE TECH
Don't know. I'm using a standalone wideband with data logging.
Old Apr 12, 2007 | 08:01 AM
QuadCam's Avatar
QuadCam
just get a bung for each side........that way you can check them out once in awhile. obviously, this is not an ideal setup, but it gives you the ability to see what the difference between banks are.....just not at the same time.
Old Apr 12, 2007 | 09:44 PM
Cannysage's Avatar
Cannysage
thanks for the input fellaz. I'll end up getting the other, one of these days.
Old Apr 13, 2007 | 06:53 AM
Dynosty's Avatar
Dynosty
What were your initial findings between the two banks - much difference?
Old Apr 13, 2007 | 07:27 AM
THE TECH's Avatar
THE TECH
90% of the time, they are very close. However, that other 10%, you can see some definite differences. IMHO, there is no reason to get a wideband if you're only gonna monitor one side of the engine.
Calinismo350z
Sep 14, 2015 04:04 PM
speedsniper
Sep 14, 2015 08:46 AM
N4Spd
Nov 18, 2003 07:40 PM
