blown ecu
Old Apr 18, 2007 | 12:07 PM
kostat26's Avatar
kostat26
Default blown ecu
i ve been having problems with my car, so i took my turbo and everything off and took it to the dealership. they said my ecu was blown. does anyone know what could cause this???. i had the unichip with aps st. the dealership said they dont know what can cause an ecu to go bad... and of course its not under warranty, cause they can tell the wires where played around with.
Old Apr 18, 2007 | 12:10 PM
bbs350z's Avatar
bbs350z
i hav no idea. bad wires? maybe a fuse? ive never heard of a blown ecu. they cant just toss a new 1 in can they?
Gman2004's Avatar
Gman2004
I've never seen anyone on this forum post about a blown ecu. Did you drive the car to the dealer or have it towed? If you drove it I'd guess the ECU isn't blown. And how does the dealer know you played with the wires if the APS ST comes with a PNP unichip? Sounds like the stealership is trying to rip you off. If your ECU is indeed blown get one from a junk yard and have the dealer reprogram your keys.
Old Apr 18, 2007 | 12:14 PM
synth19's Avatar
synth19
Exactly what kind of problems were you having? What the hell does a "blown" ecu mean? I assume you had some issues, but by saying "blown," it sounds like nothing was working with your car. Is it possible the issue is the the tune of your unichip?
Old Apr 18, 2007 | 12:27 PM
kostat26's Avatar
kostat26
i know the unichip is plug and play. but they saw the wires, where i spliced into for oil pump that comes with aps st. so they said cause of that they cant warranty the ecu.. the ecu shuts off and goes into safe mode where it acts all weird and **** like it will go wot by itself out of nowhere or my rpms wont go up at all and weird ****. they said the ecu is blown/fried they dont know why or how... and they cant do anything unless they replace it and go from there...
also i forgat to ask will a g35 rev up ecu work on my 06 rev up. and will an 05 rev up 350z ecu work?. im asking this because i found 3 ecus from 05 rev ups and g 35 rev ups but nothing for 06.
Old Apr 18, 2007 | 12:30 PM
synth19's Avatar
synth19
^ did you talk to your tuner? I would have them diagnose the problem before a dealer touches your car.
Old Apr 18, 2007 | 12:33 PM
Jay'Z's Avatar
Jay'Z
Thats fuked up.. Sorry for your experience.. How much is that gonna cost ya?
Old Apr 18, 2007 | 12:38 PM
kostat26's Avatar
kostat26
dealership wants 1000 and isnt sure if thats the problem or if my ecu will blow again and then i will have to pay another 1000 again for another one. my turbo has been out for like 4 months now trying to figure out this problem. taking it to the dealership multiple times. im taking it to a junkyard though that only works on 350zs and g35s and supras so that should cost cheaper and have parts laying around that i need. also im coming back with a tt setup after i fix my problem.
Old Apr 18, 2007 | 01:13 PM
rocks's Avatar
rocks
Any revup ECU will work on your car. You have to get the immobilizer reprogrammed and your keys at the dealer though, but it should be cheaper than a 1000$ new ecu, considering how many Zs and Gs are made there are plenty of wrecked ones. You should be able to get another one for around 200-300$.
Old Apr 18, 2007 | 01:50 PM
captj3's Avatar
captj3
Which dealer did you go to? Does anyone know if a 05 rev up ecu will work. If so I think I can get one for you.
Old Apr 18, 2007 | 02:26 PM
rocks's Avatar
rocks
05 revup ecu would work for him.
Old May 22, 2007 | 03:54 PM
schoolinz's Avatar
schoolinz
man im having the same problems but my batt. went dead i jumped it and it started and ran for about 5 seconds then shut off but everything is working but no spark on any coil at all and i think my ecu is gone too dealer wont tell me cause its turboed i have the turbo sx piggie back on it but i cant figure out what else it could be iv been workin on it for a month now and i still cant figure it out and they tell my another computer wont work if it doesnt have the same part # is there any way i could put another one in there if an one have any info let me know plz pm me cause im not to good ith this site yet and wont be sure if i can find this post again but thanks
Old May 25, 2007 | 12:09 PM
kostat26's Avatar
kostat26
hey my ecu was blown i got a used ecu and it worked good with me..
Old May 25, 2007 | 03:10 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
me too.
Shop around, even if you can not find a used one I know you can find a new one for way less than $1000 just make sure you get the right one (year and model).
Old May 25, 2007 | 08:15 PM
kostat26's Avatar
kostat26
i payed 450 for the ecu and programmed
Old May 25, 2007 | 08:52 PM
fklentz's Avatar
fklentz
Maybe the firmware was just corrupted, see if a reflash will fix it.
Old May 26, 2007 | 05:24 PM
kylekyle350z's Avatar
kylekyle350z
HEY!!!
my car is at the body shop and they called me and said they couldnt start my Z, so i called Jeff at west co nissan and they took my car over there.
They said my ECU died!!!?? wth? they dont know how this happened..
they ordered me a new one tho..
Old Sep 25, 2008 | 03:20 PM
Jay'Z's Avatar
Jay'Z
Default Big Problem!!
Another ecu possibly blown... Supposedly my ecu went out today(stealership thinks it is blown).. Dont know how the **** this would happen.... I ran low on fuel so it cut off, filled it up 1/4 tank and it would crank but not start up.. The ecu is not being recognized either by my ecu reset tool.... It is now towed to the STEALERSHIP..
Any ideas?
Old Sep 25, 2008 | 03:37 PM
rcdash's Avatar
rcdash
Check fuses. Maybe the fuel pump circuitry or the fuel pump itself died. I know some domestic fuel pumps die if you run 'em bone dry.
Old Sep 25, 2008 | 03:57 PM
Jay'Z's Avatar
Jay'Z
Originally Posted by rcdash
Check fuses.
The STEALERSHIP said they checked them and they are good.. Im not sure they checked all of them though, i remember cranking it and when i had the key in the ON position it didnt show SERVICE ENGINE SOON like it always does before you start it... How do you know if the ecu is actually blown for sure?
I did check the fuel pump fuse before my car was towed away.. It was good..
